Trim parameter values for trailing zeros C#
dusan.naus.trz
Advisor Advisor
dusan.naus.trz
What am I doing wrong? Video in the attachment
var activeDocument = ThisApplication.ActiveDocument;
var part = activeDocument as Inventor.PartDocument;
try
var m1 = "Delka";
//part.ComponentDefinition.Parameters.ModelParameters.AddByExpression(tbDelka.Text, Inventor.UnitsTypeEnum.kMillimeterLengthUnits, m1);
//part.ComponentDefinition.Parameters.ModelParameters[m1].Value = Convert.ToDouble(tbDelka.Text);
//chyba = part.ComponentDefinition.Parameters.ModelParameters[m1].Value = tbDelka.Text;
//var MyVar = part.ComponentDefinition.Parameters.ModelParameters[m1].Value = Math.Round(Convert.ToDouble(tbDelka.Text)/10,3, MidpointRounding.ToEven);
//var MyVar = part.ComponentDefinition.Parameters.ModelParameters[m1].Value = Math.Ceiling(Convert.ToDouble(tbDelka.Text) / 10);
var MyVar = part.ComponentDefinition.Parameters.ModelParameters[m1].Value = Convert.ToDouble(12345) / 10;
bradeneuropeArthur
Myvar.trailingzeros = false
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
dusan.naus.trz
I have been working in C # for only 4 days. I don't know where to put your piece of code. What will be the entire line? Where should I put it?
bradeneuropeArthur
Last line!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
dusan.naus.trz
I tried to put it on the last line and a mistake.
dusan.naus.trz
The easiest solution for me. Replace Value with Expression
string m1 = "Delka";
part.ComponentDefinition.Parameters.ModelParameters[m1].Expression = tbDelka.Text;
part.Update();
