Triggered iLogicCode only working on one machine
RNDinov8r
RNDinov8r
So, I have this code (I believe it is a provided snippet verbatum) that I run on the close of every drawing.
' Get the DXF translator Add-In.
Dim DXFAddIn As TranslatorAddIn
DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
Dim strIniFile As String
strIniFile = "C:\temp\dxfout.ini"
' Create the name-value that specifies the ini file to use.
oOptions.Value("Export_Acad_IniFile") = strIniFile
End If
'Set the destination file name
oDataMedium.FileName = ThisDoc.PathAndFileName(False) & ".dxf"
'Publish document.
DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'Launch the dxf file in whatever application Windows is set to open this document type with
When I set the trigger to run "On Close" in the drawings tab, it works fine on my machine. But it seems every other Engineering that uses this, gets an error when they close the drawing. I can't for the life of me figure out why that would be. We all point to the same directories. Even if they manually run it, they still get the same message.
bradeneuropeArthur
is this available for all machines?
Could you upload that file
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Try to change this:
oDataMedium.FileName = oDocument.PathAndFileName(False) & ".dxf"
'Publish document.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
RNDinov8r
That ini file does not even exist on my machine that I can see (Unless it is something that is being temporarily created and then removed.
When I made that change to "oDocument", then the code wouldn't run on my machine either...
bradeneuropeArthur
Take a look if these settings are the same for each machine:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
WCrihfield
Another place to check for that ini file is at the following location is under your "Design Data\ DWG-DXF\" folder.  That's where the default ones are located, and might be where your custom one is (if you have a custom one).  This is an example of the full path where that folder would default to, if you haven't changed it:
C:\Users\Public\Documents\Autodesk\Inventor 2021\Design Data\DWG-DXF\
(of course the inventor version part might be different)
Anyways, if multiple user are running this code from different PC's, that file needs to either be on a shared network location where everyone can point to it, or there needs to be a copy of the same file in the same place on everyones PC's, to avoid errors.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
