Trigger "create simplified part" via API/macro
Message 1 of 9
Hi all,
Is there a programmatic way to trigger the "Create Simplified Part" action in an assembly?
I'd like to have an assembly combined and programatically accessible as a single part. I don't mind if this creates a new document.
Jeremy
Replies (8)
Message 2 of 9
MechMachineMan
Yes. There is a sample for creating a derived component in the Programming Help.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 9
waynehelley
Hi there,
Could you point us to how to access the help files?
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
Message 4 of 9
waynehelley
Are you refering to the developer tools??
C:\Users\Public\Documents\Autodesk\Inventor 2015\SDK
Wayne Helley
Visual Studio 2022
Message 5 of 9
MechMachineMan
C:\Program Files\Autodesk\Inventor 2016\Local Help\admapi_20_0.chm
Justin K
Message 6 of 9
waynehelley
The sample Standalone Applications are;
Attributes
AutoBolts
BrowserPan
CustomGraphics
iFeatureWhereUsed
IPart
OverlayAssembly
PartFeatures
Pulley
SimpleExe
UnitsOfMeasure
UserInteraction
Wayne Helley
Visual Studio 2022
Message 7 of 9
waynehelley
Wayne Helley
Visual Studio 2022
Message 8 of 9
waynehelley
Is it the 'Shrink wrap substitute in assembly API Sample' which you are refering to?
I'm running 2015 so I may be missing some samples.
Wayne Helley
Visual Studio 2022
Message 9 of 9
MechMachineMan
Yes, or search/google "command manager/control definitions" if you just want to open the window the program shows. Though API shrinkwrap sampke method you can control all of the settings in that you would otherwise select in the dialog.
Justin K
