Trigger iLogic rule based on the value of a custom iProperty
cmcconnell
cmcconnell
So - I will start by saying I have very little programming experience. 😉
I am trying to create a rule in an .ipt that will automatically save out an igs file. My plan is to have a custom iproperty that I populate with the value of CNC.
I found the iLogic rule that ships with Inventor to save out an igs file. That part works, now I need to make it look at the iproperties to see if CNC is there in my process property.
Ideally, I would set this rule to run before save. When I hit save, it would check the process iproperty, if the property contains CNC, then it would save out the igs. if it does not contain CNC, the rule would end.
I have been looking through the group, but I have not found anything.
Mechanix Design Solutions inc.
bradeneuropeArthur
Tip.
Get more experience before running into problems in future....
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
This shouldn't be any problem with some experience and searching the web.
I will come back to it ASAP.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
cmcconnell
Thanks for the tip. I will be sure to reference it when you ask a question.
chandra.shekar.g
Autodesk Support
Autodesk Support
@cmcconnell,
Try the following iLogic code to trigger IGS creation if "Process" iPropery contains "CNC"
Try
	If iProperties.Value("Custom", "Process") = "CNC" Then
		iLogicVb.RunRule("Name of Rule to create IGS file")
Catch
	MessageBox.Show("'" + "Process" + "'" + " iProperty does not exist", "iLogic")
End Try
Triggering a iLogic rule before saving document is demonstrated in the below YouTube link.
https://www.youtube.com/watch?v=_hY2P93pr2Y
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
cmcconnell
Thanks. Using your suggestion and some help from Kent Keller, I have managed to get it working.
