Retreieve iProperty from specified file
Message 1 of 17
From a drawing, I want to retrieve a custom iProperty from a specific file. The code below works, but my file is in a parent folder. How do I specify the path for this file? If I include it directly together with the file name, it only interprets it as part of the file name, not the path..
iProperties.Value("file.iam", "Custom", "Test")
Replies (16)
Message 2 of 17
bradeneuropeArthur
From where do you want to retrieve the I-properties?
From and ipt iam idw dwg file?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 17
I want to retrieve from an iam file (file.iam) Can't figure out how to specify the path
Message 4 of 17
bradeneuropeArthur
Public Sub op()
Dim a As Application
Set a = ThisApplication
Dim b As DrawingDocument
Set b = a.Documents.Open("YOUR DOCUMENT FULL NAME", False)
'FOR EACH PROPERTY SET YOU NEED TO DEFINE Item(?).Item
'FOR EACH PROPERTY YOU NEED TO DEFINE Item(x).Item(?)
MsgBox b.PropertySets.Item(1).Item(1).Name
MsgBox b.PropertySets.Item(1).Item(1).Value
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 17
Perfect! Can I use property name instead of item number using this method?
Message 6 of 17
bradeneuropeArthur
Yes
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 17
bradeneuropeArthur
Change 1 into propertyname
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 17
bradeneuropeArthur
If you need help please let me know
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 17
bradeneuropeArthur
These are the propetysets:
  1. = Inventor Summary Information
  2. = Inventor Document Summary Information
  3. = Design Tracking Properties
  4. = Inventor User Defined Properties
then your propertyname:
like "Title"
msgbox (b.propertysets.item("Inventor Summary Information").item("Title").value)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 17
I still cant get this to work. The VBA language is also unknown to me. I've just played around with VB.net.
So, I have the assembly: file.iam
I have the path by:
SyntaxEditor Code Snippet
Dim oFile As String = "\Model\file.iam"
Dim oPath As String = ThisDoc.Path
Dim oDir As New System.IO.FileInfo(oPath)
oFull = oPath.DirectoryName + oFile
Which gives me: C:\Vault\Model\file.iam
In file.iam, there is a custom iproperty named "Tag1"
In another folder, I have a drawing. I want to retrieve Tag1 in this drawing.
Message 11 of 17
I can even open the specified file.iam by using
ThisApplication.Documents.Open(oFull, True)
 But I can not use the command SyntaxEditor Code Snippet
iProperties.Value(oFull, "Custom", "Tag1")
as it interprets oFull as a document name, not a document name + path.
Message 12 of 17
I use this code"
If ThisDrawing.ModelDocument Is Nothing Then Exit Sub
modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
iProperties.Value("Summary", "Title") = iProperties.Value(modelName,"Summary", "Title")
iProperties.Value("Project", "Description") = iProperties.Value(modelName,"Project", "Description")
iProperties.Value("Summary", "Subject") = iProperties.Value(modelName,"Summary", "Subject")
Message 13 of 17
Thanks, but that is still only referring to the model referenced in the drawing. What I can't figure out is how to link to a different file than used in the drawing. I want to retrieve these properties from an assembly in a parent folder..
Message 14 of 17
bradeneuropeArthur
Set your illogic code to straight vb . coding
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 17
bradeneuropeArthur
Don't know what you mean. Do you need to open a different dwg or the dwg from an assembly.
Please explain a little more to clarify the question...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 17
bradeneuropeArthur
Public Sub op() Dim a As Application Set a = ThisApplication Dim b As DrawingDocument Set b = a.Documents.Open("YOUR DOCUMENT FULL NAME", False) 'FOR EACH PROPERTY SET YOU NEED TO DEFINE Item(?).Item 'FOR EACH PROPERTY YOU NEED TO DEFINE Item(x).Item(?) Dim Propset as propertyset set Propset = b.PropertySets.Item("Inventor Summary Information") '= Inventor Summary Information '= Inventor Document Summary Information '= Design Tracking Properties '= Inventor User Defined Properties msgbox (Propset.Name) Dim Prop as property set Prop = Propset.item("Title") msgbox prop.Name MsgBox prop.value End Sub
This For Vb:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 17
bradeneuropeArthur
And this for illogic:
Public Sub main()
a = ThisApplication
b = a.Documents.Open("C:\Vault\Projects\Drawing1.dwg", False)
Dim Propset As PropertySet
MsgBox (Propset.Name)
Dim Prop As Inventor.Property
 Prop = Propset.Item("Title")
MsgBox (Prop.Name)
MsgBox (Prop.Value)
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
