Transaction not end
Transaction not end
bradeneuropeArthur
Mentor Mentor
Transaction not end
bradeneuropeArthur
I have an active sketch in edit (working in a 2d sketch active and open)
When I run this command in this active sketch:
Dim trm As TransactionManager = g_inventorApplication.TransactionManager
Dim tr1 As Transaction = trm.StartTransaction(g_inventorApplication.ActiveEditDocument, "MdlSketchPointsAdd.BySketchLines")
Dim ssl As Inventor.SketchLine = g_inventorApplication.CommandManager.Pick(Inventor.SelectionFilterEnum.kSketchCurveLinearFilter, "Pick One Sketchline 2D")
tr1.End()
When I in between this command press "ESC" or "FINISH SKETCH" or "END SKETCH" the transaction seems not to end and the sketch is not closed or end.
What is the reason for that?
 @johnsonshiue @CGBenner @JelteDeJong  any idea (within your team)
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
mat_hijs
When I press escape or finish the sketch it seems to end the transaction correctly. When I cancel the sketch it throws an error. I tested this in iLogic, I'm not sure if that would make a difference.
bradeneuropeArthur
That is the same as I see indeed.
Thanks for confirming
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
@johnsonshiue could this be a bug in the API?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
Solved with this check:
Dim ssl As Inventor.SketchLine = ThisApplication.CommandManager.Pick(Inventor.SelectionFilterEnum.kSketchCurveLinearFilter, "Pick One Sketchline 2D")
If not ssl is Nothing
Dim trm As TransactionManager = ThisApplication.TransactionManager
Dim tr1 As Transaction = trm.StartTransaction(ThisApplication.ActiveEditDocument, "MdlSketchPointsAdd.BySketchLines")
tr1.End()
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
