Ilogic dxf code - Drawing to dxf
Mani_RangarajanRBMBF
Message 1 of 1
Hello everyone,
I need a help with the below ilogic code, I copied from this forum, its working well. At the moment this generate dxf from the current sheet, but I want to update the code to automate the following tasks
1. Create new sheet (empty sheet)
2. Add front view of the part in 1:1
3. then adding a Sketch symbol through Insert Sketch Symbol ---> to add the symbol named ''PROFILE / DXF INFO NOTE''.
4. then to export as DXF.
Please find below the code I am using now and also snips of the symbol example how I placed on the view in the drawing.
'query user
question = MessageBox.Show("is a .DXF Export Required", "iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
          'set condition based on answer
            If question = vbYes Then
' Get the DXF translator Add-In.
path_and_nameDXF = ThisDoc.PathAndFileName(False)
Dim DXFAddIn As TranslatorAddIn
DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
Dim strIniFile As String
strIniFile = "C:\Users\Farr\Documents\Inventor\DXF_EXPORT_INI\DXF_EXPORT.ini"
oOptions.Value("Export_Acad_IniFile") = strIniFile
oDataMedium.FileName = path_and_nameDXF & ".dxf"
Call DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Replies (0)
