Tracing the center of gravity of assembly in a dynamic simulation environment
- Mute
- Permalink
- Report
Good afternoon,
It is necessary to derive information about the change in the position of the center of gravity (COG) of the mechanism when modeling its movement in a dynamic simulation environment.
Although, it is written that there is a working point connected to the COG point, it is not possible to attach the tracing to it.
While it is necessary to manually stop the simulation process, display the COG indicator and rewrite the coordinates of its position.
If this is impossible inside the Inventor (v. 2018), I would like to get a clue, how to organize it using iLogic or VBA.
As an option, the output to the text (or Excel) file would be information about the current simulation time and X, Y, Z - coordinates of the current COG position.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
