To insert a reference document in to current - Derived Part
RoyWickrama_RWEI
Advisor Advisor
Message 1 of 10
RoyWickrama_RWEI
Master skeleton (example):
"D:\Vault Workspace\Projects\A_RWEI\IEIS 10204\10204-skm0001.ipt"
Current document :
"10204-p0001x"
or full file name: "D:\Vault Workspace\Projects\A_RWEI\IEIS 10204\10204-p0001x.ipt"
Need the current document be a derived document of the master sketch as a reference document and to select parameters. I can improve to get my results, but I need help o begin with.
I request someone help me.
Thanks.
Replies (9)
Message 2 of 10
HideoYamada
Which language are you using? (VBA, iLogic, vb.net or c#?)
There is the sample code which is written in VBA.
https://forums.autodesk.com/t5/inventor-customization/ilogic-or-vb-code-derived-component/td-p/91310...
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 3 of 10
RoyWickrama_RWEI
I need to do with an iLogic rule.
Could you help.
Thanks.
Message 4 of 10
HideoYamada
This post comes back from :
https://forums.autodesk.com/t5/inventor-customization/ilogic-or-vb-code-derived-component/m-p/915414...
I created iLogic code.
Option Explicit On
Sub Main()
    Dim oDestDoc As PartDocument = ThisApplication.ActiveEditDocument
    Dim oDestDef As PartComponentDefinition = oDestDoc.ComponentDefinition
    ' This is dirty hack
    ' Change the filename from "fullpath\SKIP_DOC0035.ipt" to "fullpath\SKIP_DOC0034.ipt"
    Dim sourceFullFileName As String = oDestDoc.FullFileName
    Mid(sourceFullFileName, Len(sourceFullFileName) - 4, 1) = "4"
    ' Add Derived Part Feature
    Dim oDerivedPartComps As DerivedPartComponents = oDestDef.ReferenceComponents.DerivedPartComponents
    Dim oDerivedDef As DerivedPartUniformScaleDef = oDerivedPartComps.CreateUniformScaleDef(sourceFullFileName)
    ' Exclude all items once.
    oDerivedDef.ExcludeAll
    ' Include the first Solid.
    oDerivedDef.Solids.Item(1).IncludeEntity = True
    ' Include the visible sketches.
    For Each entity As DerivedPartEntity In oDerivedDef.Sketches
        If entity.ReferencedEntity.Visible = True Then
            entity.IncludeEntity = True
        End If
    Next entity
    ' Create the internal dictionary of parameters.
    Dim paramDic As New System.Collections.Generic.Dictionary(Of String, DerivedPartEntity)
    For Each entity As DerivedPartEntity In oDerivedDef.Parameters
        paramDic.Add(entity.ReferencedEntity.Name, entity)
    Next entity
    ' Include Parameters which name is started with "Dim_".
    For Each pair As System.Collections.Generic.KeyValuePair(Of String, DerivedPartEntity) In paramDic
        If pair.Key.StartsWith("Dim_") Then
            pair.Value.IncludeEntity = True
        End If
    Next pair
'    paramDic("Dim_d4").IncludeEntity = True
'    paramDic("Dim_d5").IncludeEntity = True
    ' Include other parameters.
    paramDic("Length").IncludeEntity = True
    paramDic("Width").IncludeEntity = True
    paramDic("Thickness").IncludeEntity = True
    ' Add the definition and create the DerivedPartFeature.
    Dim oDerivedPartComp As DerivedPartComponent = oDerivedPartComps.Add(oDerivedDef)
End Sub
I hope this code helps you.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 5 of 10
RoyWickrama_RWEI
If I run the rule for more than one time, it keeps adding the derived part and the parameters as well,
Could you help to get around the issue. Thanks.
Message 6 of 10
HideoYamada
What do you think should be done when the rule is invoked multiple times?
Ignore the execution?
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 7 of 10
RoyWickrama_RWEI
Thanks.
I got it around (using your guidance).
Option Explicit On
Sub Main
    Dim oThisActiveDoc As PartDocument = ThisApplication.ActiveEditDocument
	Dim oThisActiveDerivedDoc As PartDocument = ThisApplication.ActiveEditDocument						'Use where applicable
    Dim oThisActiveDocDef As PartComponentDefinition = oThisActiveDoc.ComponentDefinition
	Dim oThisActiveDerivedDocDef As PartComponentDefinition = oThisActiveDerivedDoc.ComponentDefinition		'where applicable
	Dim oDP_Exists_YN As String = "NO"
	If oThisActiveDoc.DocumentType <> kPartDocumentObject Then		'ThisApplication.ActiveDocument.DocumentType <> kPartDocumentObject Then
	    MsgBox("Make a Part Document the active document")
		Exit Sub
	End If
	sourceFullFileName = "D:\Vault Workspace\Projects\A_RWEI\IEIS 10204\10204-skm0001.ipt"
	sourceFullFileName = "D:\Vault Workspace\Projects\A_RWEI\SKIP-DOC0034.ipt"
	oThisActiveDoc = ThisApplication.ActiveDocument
    Dim oDerivedPartComps As DerivedPartComponents = oThisActiveDocDef.ReferenceComponents.DerivedPartComponents
	Dim oDerPartComp_Test As DerivedPartUniformScaleDef = oDerivedPartComps.CreateUniformScaleDef(sourceFullFileName)
	If oThisActiveDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Count < 1 Then
	    MsgBox("No Derived Part Components in this part")
	Else
		'Dim oDoc As Document
		'oDoc = ThisDoc.Document
		Dim oRefFile As FileDescriptor
		Dim oOrigRefName As Object
		For Each oRefFile In oThisActiveDerivedDoc.File.ReferencedFileDescriptors
		'get the full file path to the original internal ref3erences
		oOrigRefName = oRefFile.FullFileName
		Next oRefFile
		Dim oThisDerPart As DerivedPartComponent	'because this is a derived part
		For Each XX In oThisActiveDerivedDocDef.ReferenceComponents.DerivedPartComponents
			If oOrigRefName = sourceFullFileName Then oDP_Exists_YN = "YES"
'			MessageBox.Show("oOrigRefName: " _
'			& vbLf & oOrigRefName, "Title")
		Next XX
'		For i = 1 To oThisActiveDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Count
'			MessageBox.Show("Message-2: " _
'			& vbLf & oThisActiveDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Item(i).Name, "LOCAL FILE NAME!")
'		Next i
	End If
    oDerPartComp_Test.ExcludeAll
'    ' Include the first Solid.
'    oDerPartComp_Test.Solids.Item(1).IncludeEntity = True
'    ' Include the visible sketches.
'    For Each entity As DerivedPartEntity In oDerPartComp_Test.Sketches
'        If entity.ReferencedEntity.Visible = True Then
'            entity.IncludeEntity = True
'        End If
'    Next entity
    Dim oParamsDictionary As New System.Collections.Generic.Dictionary(Of String, DerivedPartEntity)
    For Each entity As DerivedPartEntity In oDerPartComp_Test.Parameters
        oParamsDictionary.Add(entity.ReferencedEntity.Name, entity)
    Next entity
    For Each oParam_to_Include As System.Collections.Generic.KeyValuePair(Of String, DerivedPartEntity) In oParamsDictionary
        If oParam_to_Include.Key.StartsWith("Dim_") Then
			oParam_to_Include.Value.IncludeEntity = True
		Else If oParam_to_Include.Key.StartsWith("At_Joint") Then
		    Try
			Catch
			End Try
        End If
    Next oParam_to_Include
'    oParamsDictionary("Dim_1").IncludeEntity = True
'    oParamsDictionary("Dim_2").IncludeEntity = True
'    ' Include other parameters.
    Try
	oParamsDictionary("HSS_Slot_GapGusset_3d4_PL").IncludeEntity = True
	Catch
	End Try
	Try
	oParamsDictionary("HSS_Slot_Rad_Fillet").IncludeEntity = True
	Catch
	End Try
If oDP_Exists_YN = "NO" Then
	MessageBox.Show("DP ADDED!", "Title")
    Dim oDerivedPartComp As DerivedPartComponent = oDerivedPartComps.Add(oDerPartComp_Test)
End If
Dim oYesNo As String
oYesNo = MessageBox.Show("Do you want to copy custom properties?", "TO COPY CUST. PROPS", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button2)
oSub_Copy_Props(oYesNo)
iLogicVb.UpdateWhenDone = True
End Sub
Sub oSub_Copy_Props(X As String)
	If X = vbYes
		Dim derivedComponent As Inventor.Document = ThisApplication.ActiveDocument
		'if there is only one reference:
		Dim referencedComponent As Inventor.Document = derivedComponent.ReferencedDocuments(1)
		Dim oProps_DerivedComp As PropertySet = derivedComponent.PropertySets.Item("Inventor User Defined Properties")
		Dim oProps_ReferencedComp As PropertySet = referencedComponent.PropertySets.Item("Inventor User Defined Properties")
		Dim oProp As Inventor.Property
		For Each oProp In oProps_ReferencedComp
		Try
		oProps_DerivedComp.Add(oProp.Value, oProp.Name)
		Catch ex As Exception
		oProps_DerivedComp.Add(oProp.Value)
		End Try
		Next
	End If
End Sub
Message 8 of 10
HideoYamada
Does your code work properly when the document contains multiple derived part features?
I think there is an issue around "For Each XX" loop.
And try consider to use a type "Boolean" instead of "String" if the variable stores only "YES" or "NO".
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 9 of 10
RoyWickrama_RWEI
It is fine for the time being.
Today, I had a problem with replacing the derived part reference. The rule I used some times ago, did not do well today. I posted finally for help, just a while ago.
Message 10 of 10
HideoYamada
According to following, I think that the 'sourceFullFileName' will be compared only with a name of the last oRefFile.
The code will work as you expect if the part document has only one DerivedPartFeature.
Next oRefFile
Next XX
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
