How to show hidden lines of an occurrence on drawing view?
Anton_Chernomazov
Message 1 of 15
Anton_Chernomazov
I need to show hidden lines of an occurrence on an drawing view with Inventor API.
I try to do it showing hidden lines for every occurrence and then disable visibility for segments of all occurrence exept target. But I'm sure that it is bad practice.
re any another ways to do it?
Replies (14)
Message 2 of 15
bradeneuropeArthur
select in the browser!
in the treeview select the part or assembly then select hidden lines..
No coding required...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 15
HideoYamada
Hi Anton,
I understand that you want to re-show the lines which are hided by a user. O.K.?
This code (VBA) re-show the all hidden lines.
Public Sub Test()
    Dim oDrawingDoc As DrawingDocument: Set oDrawingDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    For Each oSheet In oDrawingDoc.Sheets
        Dim oView As DrawingView
        For Each oView In oSheet.DrawingViews
            Dim oDrawingCurve As DrawingCurve
            For Each oDrawingCurve In oView.DrawingCurves
                Dim oDrawingCurveSegment As DrawingCurveSegment
                For Each oDrawingCurveSegment In oDrawingCurve.Segments
                    'Debug.Print oDrawingCurveSegment.Visible
                    If oDrawingCurveSegment.Visible = False Then oDrawingCurveSegment.Visible = True
                Next oDrawingCurveSegment
            Next oDrawingCurve
        Next oView
    Next oSheet
End Sub
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 4 of 15
Anton_Chernomazov
Oh, thanks! I just try it right now.
Message 5 of 15
Anton_Chernomazov
I neet to show hidden lines just for single occurrence of assembly. In User Interface I can do it with right mouse click on occurrence in Model browser and select "Show hidden lines". But I need to do it with VBA.
Message 6 of 15
bradeneuropeArthur
Sorry, but did you read my comment?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 15
Anton_Chernomazov
I know how I can do it in user interface. But I do need to do it with coding on VBA.
Message 8 of 15
bradeneuropeArthur
Where do you select the object?
  1. In the browser
  2. in the drawing view
what if the object is completely hidden and not visible in the drawing view?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 15
HideoYamada
Hi Anton,
This code re-shows hidden lines of the occurrence which contains the selected line.
At first you should select a line and then execute Test().
Public Sub Test()
    Dim oSelectedCurve As DrawingCurve
    Set oSelectedCurve = oDrawingDoc.SelectSet(1).Parent
    Dim oOcc As ComponentOccurrence
    Set oOcc = oSelectedCurve.ModelGeometry.Parent.Parent
    Debug.Print oOcc.Name
    Set oView = oSelectedCurve.Parent
    ReShowHiddenLines oView, oOcc
End Sub
Private Sub ReShowHiddenLines(oView As DrawingView, oOcc As ComponentOccurrence)
    Dim oDrawingCurves As DrawingCurvesEnumerator
    Set oDrawingCurves = oView.DrawingCurves(oOcc)
    For Each oDrawingCurve In oDrawingCurves
    Next oDrawingCurve
End Sub
You can re-show the occurrence lines by your code with using ReShowHiddenLines().
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 10 of 15
Anton_Chernomazov
It does not work in case the occurrence is hidden completely and drawing view has no one curve of this occurrence.
Message 11 of 15
HideoYamada
What is the expected workflow for doing this?
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 12 of 15
Anton_Chernomazov
I can see target occerrence on view. More over all curves of this occurrence have hidden line style.
That all equal I do right mouse click on occurrence in browser and select "Show hidden lines".
Message 13 of 15
bradeneuropeArthur
Public Sub main()
Dim CmdMan As ControlDefinition
Set CmdMan = ThisApplication.CommandManager.ControlDefinitions.Item("DrawingBodyHiddenLinesCtxCmd")
CmdMan.Execute
or ...................
CmdMan.Execute2 (True)
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 15
Anton_Chernomazov
I find necessary browser node of target occurrence and call DoSelect().
Then I execute control defenition but it does not work for me.
componentNode.DoSelect();
controlDef = inventorApp.CommandManager.ControlDefinitions["DrawingBodyHiddenLinesCtxCmd"];
controlDef.Execute();
controlDef.Execute2(true);
Message 15 of 15
Anton_Chernomazov
Thanks. I just expand every browser node before get target and it works for me.
