To automatically select a defined range in VBA.
nnn_t_ad_s_i
nnn_t_ad_s_i
I am very troubled.
I am dragging a defined area on the drawing each time to select VIEW, sketch symbols, etc.
However, the range is fixed and people do not want to drag.
Please let me know if you know anything about this.
bradeneuropeArthur
think that that is possible, but what is the reason you want to select that range.
there are other methods to select all views, sketches, symbols in a drawing more easy than using a selection range.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
HogueOne
I'm also interested in learning the solution for drag selecting entities.
