Title Block
Title Block
martinhoos
Message 1 of 23
Title Block
martinhoos
Hello together,
i have a problem with Title Blocks, i like to change the titleblock in all sheets via iLogic. With this code it only changes in the active sheet.
My script is the following (By the way, i do nothing know about iLogic, i just copy together...):
Thank you very much
Regards Martin
ActiveSheet.TitleBlock = "ET-Liste Deutsch"
Dim openDoc As Document
openDoc = ThisDoc.Document
'Dim docFile As Document
If openDoc.DocumentType = 12292 Then
    'Look For the model referenced within the drawing. End the Rule If the drawing Is empty.
    Dim MDocFile As Document
    If ThisDoc.ModelDocument IsNot Nothing Then
         MDocFile = ThisDoc.ModelDocument
         Else
         MessageBox.Show("Diese Option ist in einer leeren Zeichnung unzulässig", "Export error")
         Return
    'assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    'Set a reference to the active sheet.
    Dim oSheet As Sheet
    oSheet = oDrawDoc.ActiveSheet
    'Look for partlist within drawing. End rule, if it doesn't exist.
    'say there is a Partslist on the sheet.
    Dim oPartslist As PartsList
    oPartslist = oSheet.PartsLists(1)
    If oSheet.PartsLists(1) IsNot Nothing Then
        'set parts list to a specific style
        oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("KV-Stueli_Deutsch")
		ThisDrawing.Document.StylesManager.Layers("KV deutsch"​).Visible= True
		ThisDrawing.Document.StylesManager.Layers("KV englisch"​).Visible= False
    Else
    MessageBox.Show("Es muss eine IDW offen sein um den Code zu verwenden!", "File Type Mismatch!")
Replies (22)
Message 2 of 23
Owner2229
Hi, try it now.
Dim oDoc As Document = ThisApplication.ActiveDocument
If Not oDoc.DocumentType = 12292 Then
Exit Sub End If
' Look For the model referenced within the drawing. End the Rule If the drawing Is empty. If ThisDoc.ModelDocument Is Nothing Then MessageBox.Show("Diese Option ist in einer leeren Zeichnung unzulässig", "Export error") Exit Sub End If ' Assumes a drawing document is active. Dim oDrawDoc As DrawingDocument = oDoc ' Go throught every sheet. Dim oSheet As Sheet
For Each oSheet In oDrawDoc.Sheets ' Look for partlist within the sheet. Dim oPartsList As PartsList = oSheet.PartsLists(1) If oPartsList IsNot Nothing Then ' Set parts list to a specific style oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("KV-Stueli_Deutsch") ThisDrawing.Document.StylesManager.Layers("KV deutsch"​).Visible= True ThisDrawing.Document.StylesManager.Layers("KV englisch"​).Visible= False End If Next
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 23
martinhoos
Thank you Mike,
but, the code did not run, there is a message:
Fehler in Regel: neu in Dokument: Test-ET-Liste_58001926.idw
Falscher Parameter. (Ausnahme von HRESULT: 0x80070057 (E_INVALIDARG))
Maybe it is because i work with Inventor 2015?
Regards from germany
Martin
Message 4 of 23
Owner2229
Hi, the problem is probably in the code as it says "wrong parameter". I have probably just made a misstake in it.
Can you please send the screenshots of both pages of the error message please?
Mike
Message 5 of 23
martinhoos
Here it is... :
Message 6 of 23
Owner2229
Alright, the problem is in this line:
It can't find the item. Can you please use this code and verify if the style is in the output?
    Exit Sub
    Exit Sub
Dim oSheet As Sheet
Dim oStyle As Style
Dim oT As String = ""
For Each oStyle In oDrawDoc.StylesManager.PartsListStyles
    oT = oT & vbLf & oStyle.Name
Next
MsgBox(oT)
Mike
Message 7 of 23
martinhoos
Thanks again...
Here it is.
Regards
Martin
Message 8 of 23
martinhoos
Hello Mike,
once again, i checked the code below, it runs (all thinks changed). The only problem is, that the changings are only on the first sheet (page1).
I like to have all sheets changed.
Regards Martin
         Else
         Return
    Dim oSheet As Sheet
    Else
Message 9 of 23
martinhoos
Hello Mike,
if i copy the code out of my last post and paste it into the drawing, i get the message:
Fehler in Regel: Regel6 in Dokument: Test-ET-Liste_58001926.idw
Maybe there is a probleme with copy and paste? What do i wrong?
Regards Martin
Message 10 of 23
Owner2229
Try it now.
    Exit Sub
    Exit Sub
' Get the style
Dim oStyle As Style
For Each aStyle As Style In oDrawDoc.StylesManager.PartsListStyles
    If aStyle.Name = "KV-Stueli_Deutsch" Then
        oStyle = aStyle
        Exit For
Next
' End the Rule if the Style doesn't exist If oStyle Is Nothing Then Exit Sub ' Go throught every sheet. Dim oSheet As Sheet For Each oSheet In oDrawDoc.Sheets ' Look for partlist within the sheet. If oSheet.PartsLists(1) IsNot Nothing Then ' Set parts list to a specific style Dim oPartsList As PartsList = oSheet.PartsLists(1) oPartsList.Style = oStyle oDrawDoc.StylesManager.Layers("KV deutsch"​).Visible= True oDrawDoc.StylesManager.Layers("KV englisch"​).Visible= False End If Next
Mike
Message 11 of 23
martinhoos
Hello Mike,
it looks better...
The first sheet is well done, on the second sheet only the parts list changed. The titleblock and the layer did not.
Regards Martin
Message 12 of 23
Owner2229
Ok, this should now work for the Titleblock and the Layers.
    Exit Sub
    Exit Sub
' Get the style
Dim oStyle As Style
        oStyle = aStyle
        Exit For
Next
' Go throught every sheet. Dim oSheet As Sheet For Each oSheet In oDrawDoc.Sheets oSheet.TitleBlock = "ET-Liste Deutsch" ' Look for partlist within the sheet. If oSheet.PartsLists(1) IsNot Nothing Then ' Set parts list to a specific style oSheet.PartsLists(1).Style = oStyle
' Change the Layers
Dim oLayers As LayersEnumerator = oSheet.Parent.StylesManager.Layers
oLayers.Item("KV deutsch"​).Visible= True
oLayers.Item("KV englisch"​).Visible= False
Next
Mike
Message 13 of 23
martinhoos
Hello Mike,
i get the message:
Regelkompilierungsfehler in Regel6, in Test-ET-Liste_58001926.idw
Fehler in Zeile 32 : Die Eigenschaft "TitleBlock" ist ReadOnly.
Regards Martin
Message 14 of 23
Owner2229
    Exit Sub
    Exit Sub
' Get the style
Dim oStyle As Style
        oStyle = aStyle
        Exit For
Next
' Go throught every sheet. Dim oSheet As Sheet For Each oSheet In oDrawDoc.Sheets oSheet.TitleBlock.Delete
oSheet.AddTitleBlock = "ET-Liste Deutsch" ' Look for partlist within the sheet. If oSheet.PartsLists(1) IsNot Nothing Then ' Set parts list to a specific style oSheet.PartsLists(1).Style = oStyle
' Change the Layers
Next
Mike
Message 15 of 23
martinhoos
Hello Mike,
this message appears:
Fehler in Zeile 33 : Für den Parameter "TitleBlockDefinition" von "Public Function AddTitleBlock(TitleBlockDefinition As Object, [TitleBlockLocation As Object], [PromptStrings As Object]) As Inventor.TitleBlock" wurde kein Argument angegeben.
Regards Martin
Message 16 of 23
Owner2229
    Exit Sub
    Exit Sub
' Get the style
Dim oStyle As Style
For Each aStyle As Style In oDoc.StylesManager.PartsListStyles
        oStyle = aStyle
        Exit For
Next
' Go throught every sheet. Dim oSheet As Sheet For Each oSheet In oDoc.Sheets oSheet.TitleBlock.Delete
oSheet.AddTitleBlock("ET-Liste Deutsch") ' Look for partlist within the sheet. If oSheet.PartsLists(1) IsNot Nothing Then ' Set parts list to a specific style oSheet.PartsLists(1).Style = oStyle
' Change the Layers
Next
Mike
Message 17 of 23
martinhoos
Hello Mike,
it works - Thank you very much....
Regards Martin
Message 18 of 23
Owner2229
You're welcomed. I'm sorry I haven't made it right at once, but I'm a bit distracted today Smiley Happy
Mike
Message 19 of 23
martinhoos
Hi Mike, its me again... there is one probleme left with the code. If i have a sheet in without partlist, i get the message:
Fehler in Regel: ET_Liste_Deutsch in Dokument: Test-ET-Liste_58001926.idw
Can you help me agai? Thanks a lot!
Regards
Martin
Message 20 of 23
MechMachineMan
    Exit Sub
    Exit Sub
' Get the style
Dim oStyle As Style
        oStyle = aStyle
        Exit For
Next
Dim oSheet As Sheet
    If oSheet.PartsLists.Count > 0 Then
        ' Change the Layers
Else if oSheet.PartsLists.Count > 1
MsgBox("More than 1 PartsList found on the sheet. Please fix
Exit Sub
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
