Title Block
Title Block
martinhoos
Message 1 of 23
Title Block
martinhoos
Hello together,
i have a problem with Title Blocks, i like to change the titleblock in all sheets via iLogic. With this code it only changes in the active sheet.
My script is the following (By the way, i do nothing know about iLogic, i just copy together...):
Thank you very much
Regards Martin
ActiveSheet.TitleBlock = "ET-Liste Deutsch"
Dim openDoc As Document
openDoc = ThisDoc.Document
'Dim docFile As Document
If openDoc.DocumentType = 12292 Then
    'Look For the model referenced within the drawing. End the Rule If the drawing Is empty.
    Dim MDocFile As Document
    If ThisDoc.ModelDocument IsNot Nothing Then
         MDocFile = ThisDoc.ModelDocument
         Else
         MessageBox.Show("Diese Option ist in einer leeren Zeichnung unzulässig", "Export error")
         Return
    'assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    'Set a reference to the active sheet.
    Dim oSheet As Sheet
    oSheet = oDrawDoc.ActiveSheet
    'Look for partlist within drawing. End rule, if it doesn't exist.
    'say there is a Partslist on the sheet.
    Dim oPartslist As PartsList
    oPartslist = oSheet.PartsLists(1)
    If oSheet.PartsLists(1) IsNot Nothing Then
        'set parts list to a specific style
        oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("KV-Stueli_Deutsch")
		ThisDrawing.Document.StylesManager.Layers("KV deutsch"​).Visible= True
		ThisDrawing.Document.StylesManager.Layers("KV englisch"​).Visible= False
    Else
    MessageBox.Show("Es muss eine IDW offen sein um den Code zu verwenden!", "File Type Mismatch!")
Replies (22)
Message 21 of 23
Owner2229
Here you go:
Dim oDoc As Document = ThisApplication.ActiveDocument
If Not oDoc.DocumentType = 12292 Then
    Exit Sub
' Look For the model referenced within the drawing. End the Rule If the drawing Is empty.
If ThisDoc.ModelDocument Is Nothing Then MessageBox.Show("Diese Option ist in einer leeren Zeichnung unzulässig", "Export error") Exit Sub End If ' Get the style Dim oStyle As Style For Each aStyle As Style In oDoc.StylesManager.PartsListStyles If aStyle.Name = "KV-Stueli_Deutsch" Then oStyle = aStyle Exit For End If Next ' End the Rule if the Style doesn't exist If oStyle Is Nothing Then Exit Sub
' Go throught every sheet. Dim oSheet As Sheet For Each oSheet In oDoc.Sheets oSheet.TitleBlock.Delete
oSheet.AddTitleBlock("ET-Liste Deutsch") ' Look for partlist within the sheet.
If oSheet.PartsLists.Count = 0 Then Continue For If oSheet.PartsLists(1) IsNot Nothing Then ' Set parts list to a specific style oSheet.PartsLists(1).Style = oStyle
' Change the Layers
Dim oLayers As LayersEnumerator = oSheet.Parent.StylesManager.Layers
oLayers.Item("KV deutsch"​).Visible= True
oLayers.Item("KV englisch"​).Visible= False
Next
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 22 of 23
martinhoos
Hi Mike,
thank you very much.... !
Regards
Martin
Message 23 of 23
martinhoos
I gamble the language with the code, so far it looks great, but there is just a little problem. If i have two sheets in my IDW with text in and i call the code, the layer "kv englisch" will switched off and the layer "kv deutsch" will switched on - the first sheet will be ok. But the second sheet changed not correct, the old layer is visible...
Hope there is a solution to solve that problem.  😉
Thank you very much....
Regards
Martin
    Exit Sub
    Exit Sub
' Get the style
Dim oStyle As Style
        oStyle = aStyle
        Exit For
Next
Dim oSheet As Sheet
        ' Change the Layers
        ThisApplication.ActiveView.Update()
Next
