Title block of sheet 2 problem
Hi.
Have been searching the forum and not found a solution to my problem.
Found one that had the same problem as me but the solution dont work for me.
Can have up to 30 diffrent parts.(alot of diffrent representation views to make)
http://forums.autodesk.com/t5/inventor-customization/title-block-of-sheet-2-issue/m-p/5490943#M53885
Is there another way to solve it? Using iLogic or so?
Jesper
bretrick30
You could change your title block to pull the information from some Custom iProperties in the drawing.  Then have an iLogic rule that will pull the properties from the model on Sheet 1 and assign them to the Custom iProperties in the drawing, which will then show up on all sheets.
Jesper_S
Hi.
Sorry for the late reply.
Good idea. I only have one problem with that.
Dont know how to write the iLogic code to do that.
Know how to create custom iProperties but thats about it.
Need code to assign properties for
-Part Number
-Mass
-Title
-Scale
//Jesper
//Jesper
MechMachineMan
Why not just use prompted entries and have iLogic pull and populate information from the first view on the first sheet?
Or do you need the information within all of the parts for some reason that you would want to have them as custom properties?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Jesper_S
Hi.
i had that for the scale before. Got the scale from the first view of sheet 1.
but when i create sheet 2 and placed a view there, then sheet 2 scale in the titleblock gets its scale from the first view in sheet 2, not sheet 1.
Same thing with mass. Perhaps my iLogic code needs a bit tweeking.
So for now i have iLogic pull the iProperties from the first view and assign it to the drawings iProperies. but for scale and mass i create a custom iProperty.
it works but i guess there is a more effective and simple way.
//jesper
//Jesper
MechMachineMan
Won't pulling the mass and scale from the model/sheet properties accompish what you need, rather than the drawing properties?
Justin K
