Task Sheduler Examples Custom Tasks
bradeneuropeArthur
Mentor Mentor
Message 1 of 10
bradeneuropeArthur
Doe anybody have "Task Scheduler" Examples for creating Custom Tasks via Vb.net?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Replies (9)
Message 2 of 10
Frederick_Law
Message 3 of 10
Michael.Navara
You can easily create custom EXE application in VB.NET and use them in TaskSheduler. Sample is in attachment and here is the screen shot from TaskScheduler configuration. Sample is for Inventor 2024.
This custom task only prints the PartNumber and full file name of all *.ipt files in given directory. It uses ApprenticeServer. For full Inventor it is similar, but slower and little bit more code.
Message 4 of 10
bradeneuropeArthur
Hi @Michael.Navara ,
I have created a Console Application via Vb.net with this only in the Main sub:
bradeneuropeArthur_0-1700341687270.pngbradeneuropeArthur_1-1700341784336.pngbradeneuropeArthur_2-1700341815580.png
But nothing happens with the  task scheduler.
Any idea what is wrong.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 10
Michael.Navara
I'm not sure you can easily use MsgBox in console application without additional references to Windows.Forms etc. But I expect you successfully test your application.
In this case the issue can be in starting.
I create new console application with following code and it work as expected. I only change MkDir to CreateDirectory function, because MkDir fails when directory exists.
Module Module1
    Sub Main()
        MsgBox("Test")
        'MkDir("C:\Temp\test")
        System.IO.Directory.CreateDirectory("C:\Temp\test")
    End Sub
End Module
Everything work as as expected.
Message 6 of 10
bradeneuropeArthur
Also without the MkDir the task does not run.
Don't know what is wrong.
If I debug the application selves it works correct. but with the task scheduler not.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 10
bradeneuropeArthur
Please see the movie:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 10
Michael.Navara
Try this steps, I don't know what's wrong 🤔
EDIT: Sample added
Message 9 of 10
bradeneuropeArthur
Hi, @Michael.Navara
I have found the issue.
There is a difference in the Task Scheduler when pasting the path of the .exe file in the dialog.
You must use the search button and then add the exe and not copy and past the path,
Thanks for supporting on this, appreciated...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 10
Michael.Navara
That's it! 😉
You can use copy+paste, but you need to remove quotation marks ( " )
