Tab Text
Tab Text
isocam
Tab Text
isocam
Can anybody help?
I am writing a Vb.Net "Addin" for inventor that creates HTML code.
I need to be able to "TAB" the right most string so that the output lines up.
For example (Before TAB),
1 HELLO
12 TO
123 THE
1234 WORLD
However, I need the right hand text to line up, thus....
1                  HELLO
12                TO
123              THE
1234            WORLD
Does anybody know how to do this using HTML "TAB" as the left side text can be anything from one to 20 characters in length???
Many thanks in advance!
Darren
bradeneuropeArthur
Maybe this will help you!
https://linuxhint.com/html-insert-tab-space-characters-code/
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Michael.Navara
If you want to build HTML, use HTML table
Sample
HELLO
12 TO
123 THE
1234 WORLD
Source code
<table border="1" width="100%">
    <tbody>
        <tr>
            <td>1</td>
            <td>HELLO</td>
        </tr>
        <tr>
            <td>12</td>
            <td>TO</td>
        </tr>
        <tr>
            <td>123</td>
            <td>THE</td>
        </tr>
        <tr>
            <td>1234</td>
            <td>WORLD</td>
        </tr>
    </tbody>
</table>
