Tab functionality through controls on an Inventor Add-in winform
Tiffany_Hayden_
Message 1 of 8
Tiffany_Hayden_
I have a form that instantiated on a button click on custom ribbon for a custom add-in. I'm noticing some behavior that is odd and after a lot of research I think it's Inventor application causing this behavior.
Controls
3 text boxes, tab index is 1, 2, 3 where tabstop = True for all three. All other label controls have a greater than 3 tab index.
Form
KeyPreview Property = True
What occurs is when a tab happens after the form loads the windows chime sounds like it is not allowed.
Has anyone had this situation where tab was not allowed on a windows form within a custom addin? If so what did you do?
Thanks!
Tiffany Hayden
Replies (7)
Message 2 of 8
bradeneuropeArthur
Do you use show or showdialog?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
Tiffany_Hayden_
I'm currently using .show on my form.
Tiffany Hayden
Message 4 of 8
bradeneuropeArthur
Could you try showdialog, if that makes difference?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
Tiffany_Hayden_
I definitely will try that!
Tiffany Hayden
Message 6 of 8
Tiffany_Hayden_
@bradeneuropeArthur Changing it from show to showdialog worked! Thanks so much!
Tiffany Hayden
Message 7 of 8
bradeneuropeArthur
Sometimes the solution is closer than is thought.
Let me know if you have any other or programming related issues.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 8
Tiffany_Hayden_
Yes I searched high and low! That's why I love the forums. So many people that have so much experience in one place. I'm so glad we have this community. 😊😊
Tiffany Hayden
