switch driven dimensions
Nathan.r12345
Nathan.r12345
Hi, i was hoping someone can help me.
Is it possible using iLogic to switch two params between driven and undriven dimensions.
I basically have an object in the middle of a room and i want to be able to choose an offset distance from a wall, based on which side of the room its on. Ie left or right.
So in a form the user would click 'left side of room' and then input the offset from the left wall or vise versa.
See attched image.
For example:
if SWITCHDIRVENDIMENSION = True Then
d2 = Not driven
d3 = Driven dimension
if SWITCHDIRVENDIMENSION = False Then
d2 = Driven dimension
d3 = Not driven
bradeneuropeArthur
I have a addin for that. Let me have a look to share this ....
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Dim p As PartDocument = ThisDoc.Document
Dim pc As PartComponentDefinition = p.ComponentDefinition
Dim ps As PlanarSketch = pc.Sketches.Item(1)
Dim skd1 As DimensionConstraint = ps.DimensionConstraints.Item(1)
Dim skd2 As DimensionConstraint = ps.DimensionConstraints.Item(2)
MsgBox(skd1.Driven)
MsgBox (skd2.Driven)
If skd1.Driven = True Then
	skd2.Driven = True
	skd1.Driven = False
Else If skd2.Driven = True Then
	skd1.Driven = True
	skd2.Driven = False
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
Or even with a pick-command:
Dim s As SelectSet = p.SelectSet
skd1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchDimConstraintFilter, "PICK FIRST ""DRIVEN"" DIMENSION TO SWITCH!")
Do While skd1.Driven = False
	MsgBox ("THIS DIMENSION IS NOT DRIVEN")
Loop
skd2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchDimConstraintFilter, "PICK FIRST ""DRIVE"" DIMENSION TO SWITCH!")
Do While skd2.Driven = True
	MsgBox ("THIS DIMENSION DOES NOT DRIVE")
Loop
Try
	skd2.Driven = True
	skd1.Driven = False
	skd1.Driven = True
	skd2.Driven = False
Catch
	MsgBox("NOT POSSIBLE TO SWITCH!")
End Try
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
