What is going on? Occurrence.SurfaceBodies Count is zero for parts with no solid parts
wfajber
wfajber
Dim occ As Inventor.ComponentOccurrence
occ = ThisApplication.CommandManager.Pick(Inventor.SelectionFilterEnum.kAssemblyOccurrenceFilter, "pick an occurrence")
Logger.Info("For part " & occ.Name & " The number of surface bodies is " & occ.SurfaceBodies.Count)
I was debugging a rule, and I became confused about surfacebodies.   I was adding a part that is nothing but surface.  I was repurposing a rule that got an edge from a occurrence, which worked great.  I switched to a part that does not have any solids, and it failed.
Here are two parts. They are identical except in one of them I extruded the profile as a surface instead of a solid.
When I select the occurrence of the solid part, the number of SurfaceBodies= 1.
But when I select the occurrence of the surface part, the number of SurfaceBodies= 0.
But I can see it. In the model browser, I can see a surface in the SurfaceBody browser.
Clearly there is a subtlety around how a how an occurrence displays the surface. Can anyone explain this?
vpeuvion
Michael.Navara
I don't know how it is designed, but you can obtain WorkSurfaces from occ.Definition.WorkSurfaces
Logger.Info("For part " & occ.Name & " The number of work surfaces is " & occ.Definition.WorkSurfaces.Count)
Note: Both models are empty ☹️
