12:07 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi!
I have an ilogic script which export my part to a STEP file. Which works great by the way. The problem is that when I order the parts, to be made by a laser cutter for example, the diameter of the coutersunk holes are lasered according to the largest diameter of the hole. Is there a way to suppress countersunk holes when exporting? Or even better, change them to a regular hole with the same diameter? I do the same with chamfer features and that works but I don't know how to separtate a normal hole from an countersunk hole.
Thanks in advance!
Below the ilogic rule I currently use for exporting the stp file
'Set path oJaar = "20" & Left(ThisDoc.FileName(False), 2) oPath = "\\10.135.4.60\dxf-pdf\" & oJaar & "\" & Left(ThisDoc.FileName(False), 6) & "\" & Mid(ThisDoc.FileName(False), 7,3) & "\" 'Open document curDoc = ThisDrawing.Sheet("sheet:1").View("VIEW1").ModelDocument If curDoc.DocumentType = kPartDocumentObject Then oDoc = ThisApplication.Documents.Open(curDoc.FullFileName, True) oCompDef = oDoc.ComponentDefinition 'Supress all chamfers Dim oEachF As PartFeature 'iterare each feature For Each oEachF In oCompDef.Features 'if it is a chamfer or fillet If TypeOf oEachF Is ChamferFeature Or TypeOf oEachF Is FilletFeature Then 'suppress it oEachF.Suppressed = True End If Next ' Get the STEP translator Add-In. Dim oSTEPTranslator As TranslatorAddIn oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}") Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then ' Set application protocol. ' 2 = AP 203 - Configuration Controlled Design ' 3 = AP 214 - Automotive Design oOptions.Value("ApplicationProtocolType") = 3 ' Other options... oOptions.Value("Author") = iProperties.Value("Summary", "Author") 'oOptions.Value("Authorization") = "" oOptions.Value("Description") = iProperties.Value("Project", "Part Number") & " " & iProperties.Value("Project", "Description") oOptions.Value("Organization") = "Madolex-Somatech" oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism Dim oData As DataMedium oData = ThisApplication.TransientObjects.CreateDataMedium 'Set the Step target file name with revision ' If iProperties.Value("Project", "Revision Number") >"0" Then ' oName= ThisDoc.FileName(False)& "-REV_" & iProperties.Value("Project", "Revision Number") ' Else ' oName = ThisDoc.FileName(False) ' End If 'Set the Step target file name without revision oName = ThisDoc.FileName(False) 'Export Step oData.FileName = oPath & oName & ".stp" oPath2= oData.FileName oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData) End If 'Unsupress all chamfers For Each oEachF In oCompDef.Features 'if it is a chamfer or fillet If TypeOf oEachF Is ChamferFeature Or TypeOf oEachF Is FilletFeature Then 'suppress it oEachF.Suppressed = False End If Next ThisApplication.ActiveDocument.Close End If
