Store InputBox value somewhere in the applcation
rcolon9E4ZX
rcolon9E4ZX
I have a macro for importing CAD files. I have an inputbox where I ask the user to specify the manufacturer. I am trying to store this MFG for the next time the macro runs. I am trying a global variable, but after the program quits, the next time it runs the global is cleared.
Public LastStrMFG 'global
'Specify the manufacturer
Dim strMFG As String
strMFG = InputBox("Who is the manufacturer? Leave blank if saving outside of Purch.", "Specify manufacturer", LastStrMFG)
'Here is where I want to store the input for the next execution
LastStrMFG = strMFG
I have gotten around this in the past by storing/recalling values in a file. This is more complicated than I want to do for what could simply be a retained value stored somewhere in the project. How do I do this? There are several spots where I could use this functionality.
Any help would be appreciated. Thanks.
Rafael
bradeneuropeArthur
With a add in this is easier to do then with ilogic and vba.
For ilogic and vba I would use a text file and read and write the manufacturer name....
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
frederic.vandenplas
You can use the registry to store your values.
https://stackoverflow.com/questions/1250455/read-and-write-to-the-registry-with-vb-net
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
