Stopping active command
prakash.muthu
Message 1 of 10
prakash.muthu
Is there any options to stop current command from execution.
Replies (9)
Message 2 of 10
marcin_otręba
try :
CommandManager.StopActiveCommand()
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 3 of 10
prakash.muthu
StopActiveCommand() causing application crash
Message 4 of 10
bradeneuropeArthur
Which command do you try to stop then?
public sub main()
dim a as application
set a as thisapplication
a.CommandManager.StopActiveCommand
End Sub
seems normally to work well....
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 5 of 10
prakash.muthu
I want to stop save command
Message 6 of 10
marcin_otręba
for this you should use;
ApplicationEvents.OnSaveDocument( DocumentObject As Document, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, HandlingCode As HandlingCodeEnum )
Message 7 of 10
prakash.muthu
No. StopActiveCommand() is not stopping the save operation in OnSaveDocument event.
Message 8 of 10
marcin_otręba
I didn't mean that you should use StopActiveCommand inside save event. you should use onsavevent instead of StopActiveCommand.
Then you can determine if event is handled, if yes then save will not occur.
Message 9 of 10
prakash.muthu
OnSaveDocument event will not stop the save operation. How to cancel the operation inside OnsaveDocument event?
Message 10 of 10
marcin_otręba
 first run your code before save - you can determin it by BeforeOrAfter  paramter.
then f you want to brake save operation change parameter HandlingCode  to keventhandled or keventcancelled.
