STEP Conversion based on File
RNDinov8r
RNDinov8r
So, I stumbled upon this genius little code snippet which is included in Inventor.
' Get the STEP translator Add-In.
Dim oSTEPTranslator As TranslatorAddIn
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
    ' Set application protocol.
    ' 2 = AP 203 - Configuration Controlled Design
    ' 3 = AP 214 - Automotive Design
    oOptions.Value("ApplicationProtocolType") = 3
    ' Other options...
    'oOptions.Value("Author") = ""
    'oOptions.Value("Authorization") = ""
    'oOptions.Value("Description") = ""
    'oOptions.Value("Organization") = ""
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oData As DataMedium
    oData = ThisApplication.TransientObjects.CreateDataMedium
    oData.FileName = ThisDoc.PathAndFileName(False) & ".step"
oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
End If
Based on my playing around with it, if I set it to trigger on an event, say, "After Save", it only creates/updates the step file if it does not exist or the part has changed. This is exactly the behavior I am looking for.  I have saved this code to an external rule (see above). My only change is that we save to "STEP", and not "STP"...so I tweaked that code.
I am wondering is there a way to run this so that If I apply this external rule to both Parts and Assemblies, that I can save to STEP based on the Part number "scheme"?
We have M, A, P, C, & Z numbers. so they would be for example:
M10001234.ipt
A10000246.iam
P10003579.ipt/.iam
C10002468.ipt/.iam
Z10003142.iam
Because C & Z, can be .iam files I could apply this accross the board, however, I don't want to convert P or A numbers to STEP files. A-numbers could be massive assemblies...so on the fly conversion would be major time suck. And we don't need P-Numbers as STEP files, since those are purchased parts and we don't send neutral files of those to our vendors.
So is it possible to modify the code to say If FileName starts with "M", "C", or "Z" that it converts, otherwise it ignores the coversion?
Accepted solutions (3)
bradeneuropeArthur
You mean like:
If filename.contains(M) or filename.contains(A) then
Do this
Else
Do that
End if
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
RNDinov8r
Yes, I beleive so, specifically:
If filename.contains(M) or filename.contains(C) or filename.contains(Z) then
"Convert to STEP"
Else
"Do Nothing"
End if
bradeneuropeArthur
Try this:
Public Sub Main'(oThisApplication As Inventor.Application,oThisDoc As thisdo)
If ThisDoc.FileName.Contains("M") Or ThisDoc.FileName.Contains("C") Or ThisDoc.FileName.Contains("Z") Then
'MsgBox (osteptranslator.Description)
'MsgBox (oContext.Type)
'MsgBox (ThisDoc.FileName)
If oSTEPTranslator.HasSaveCopyAsOptions(ThisDoc.Document, oContext, oOptions) Then
'MsgBox (Thisapplication.ActiveDocument.PathAndFileName)
    ' Other options...
    Dim oData As Inventor.DataMedium
	MsgBox ("")
    'oData.FileName = ThisDoc.PathAndFileName(False) & ".step"
	oData.FileName = ThisDoc.ChangeExtension("step") '& ".step"
	msgbox (odata.FileName)
oSTEPTranslator.SaveCopyAs(ThisDoc.Document, oContext, oOptions, oData)
End If
End If
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
WCrihfield
I was going to suggest leaving that block of code as it's own separate Sub, then simply having a conditional check in you main code, that controls when to call it, like this:
Sub Main
	Dim oFName As String = ThisDoc.FileName(False)
	If oFName.StartsWith("M") Or oFName.StartsWith("C") Or oFName.StartsWith("Z") Then
		ExportStep
	End If
End Sub
Sub ExportStep()
	Dim oSTEPTranslator As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
	Dim oTO As TransientObjects = ThisApplication.TransientObjects
	Dim oContext As TranslationContext = oTO.CreateTranslationContext
	Dim oOptions As NameValueMap = oTO.CreateNameValueMap
	Dim oData As DataMedium = oTO.CreateDataMedium
	    ' Other options...
	End If
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
bradeneuropeArthur
@RNDinov8r
The base code was giving an error on different points, so I have modified it a bit to a more working code.
Maybe you we can combine them!
Sub Main
		ExportStep
	End If
End Sub
'Sub ExportStep()
Public Sub ExportStep'(oThisApplication As Inventor.Application,oThisDoc As thisdo)
'If ThisDoc.FileName.Contains("M") Or ThisDoc.FileName.Contains("C") Or ThisDoc.FileName.Contains("Z") Then
    ' Other options...
	MsgBox ("")
End If
'End If
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
