speed up i Logic rules in assembly
I've created an assembly with a couple of rules which help the user to create and sort the correct parts and demensions for the assembly.
it works perfect, only takes about 8-10 minutes..
Is there a trick or something to speed things up here?
kind of like the rollup EOP function in part level, only now for assembly.?
tolgay.hickiran
It would be difficult to comment without seeing the code but heres a couple of issues we face;
- Using your "key" parameters on the top assembly level makes it a bit faster to solve.
- Constraining to planes for some of the parts is also likely to solve the assembly faster.
Some worthwhile ideas
Copy Design should rename ilogic Rules too!
Why Nastran In-CAD doesn't have an SDK?IMPLEMENTED!
Tolgay Hickiran
Founding Partner
SignatureSignature
website
emailskypelinkedinyoutubeemail
