ReplaceReference on "Piping Runs Environment" assembly does not work instantly
I have an Inventor Addin and i am using Inventor API.
I want to rename a complete assembly-structure that contains a piping assembly.
The Problem is that Inventor does not recognize the changes instantly and does not find the routes:
2016-06-20 10_03_53-Inventor Kopieren von Generator Baugruppen.docx - Word.png
I have a function which renames all models recursively, using replaceReference:
For Each childDoc As Document In activeDocument.ReferencingDocuments
  oFileDescriptors = childDoc.File.ReferencedFileDescriptors
  For descriptorCount = 1 To oFileDescriptors.Count
    Try
      If String.Compare(oFileDescriptors.Item(descriptorCount).FullFileName, filePath, True) = 0 Then
              oFileDescriptor = oFileDescriptors.Item(descriptorCount)
              oFileDescriptor.ReplaceReference(newFilePath)
    Catch exc As Exception
    End Try
  Next descriptorCount
Next
What can I do that Inventor recognizes the changes correctly?
It is no option to reopen assemblies, because opening of large assemblies is too slow.
thanks
-marcus
I solved the Problem switching to LevelOfDetailEnum.kAllPartsSuppressedLevelOfDetail and back.
I did not understand it fully. whose lod did you change and run. Could you please explain a bit more in detail
I switched it on the main Assembly like that:
 If m_application.ActiveDocument.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
                        With DirectCast(m_application.ActiveDocument, AssemblyDocument)
                            Dim alvl = .ComponentDefinition.RepresentationsManager.ActiveLevelOfDetailRepresentation
                            For Each lvl As LevelOfDetailRepresentation In .ComponentDefinition.RepresentationsManager.LevelOfDetailRepresentations
                                If lvl.LevelOfDetail = LevelOfDetailEnum.kAllPartsSuppressedLevelOfDetail Then
                                    lvl.Activate()
                                    Exit For
                            Next
                            'switch back
                            alvl.Activate()
                        End With
thank you. working
