Solid bodies not updating with part file
Hi guys,
I have designed a part with six solid bodies and made a separate assembly file using make component command.
It is very common practice I have using for a long where you change any dimension in part file, update will reflect on to your solid bodies as well as assembly. For some reason, it is not updating with this particular file, any ideas why is it doing?
Software - 2020 Inventor
Cheers
A.Acheson
Can you explain a little more about what changes your making that are not updating? Maybe with a video etc? Have you added any solid bodies?
Regards
Alan
bradeneuropeArthur
Can you make a screenshot from the tree browser in inventor
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
