Missing Reference STEP
m.schrepfer
Message 1 of 8
m.schrepfer
I´v an error by opening an assembly with missing reference.
I´ve made an copy of the assembly, deleted all components and the error continues to occur.
I´ve found no referenced document or referenced files but an entry under File/ReferencedFileDescriptor/Item1/...
Is there a possibility to delete this reference?
Markus Schrepfer
Replies (7)
Message 2 of 8
A.Acheson
Maybe try this link, there  is a VBA version in there. Maybe ensure to copy file before deleting the occurrence.
https://forums.autodesk.com/t5/inventor-customization/ilogic-check-for-and-delete-all-unresolved-com...
Regards
Alan
Message 3 of 8
m.schrepfer
Hi @A.Acheson
Thanks for your tipp.
But this don´t work
If oFileDescriptor.ReferencedDocument = nothing then
   delete oFileDescriptor
 And the other code only deletes Occurences but I don´t have this missing file in the occurences.
Private Sub ProcessReferences(ByVal oFile As Inventor.File, oDoc As AssemblyDocument, oDocDef As ComponentDefinition)
        Dim oFileDescriptor As FileDescriptor
        For Each oFileDescriptor In oFile.ReferencedFileDescriptors
            If Not oFileDescriptor.ReferenceMissing Then
                If Not oFileDescriptor.ReferencedFileType = FileTypeEnum.kForeignFileType Then
                    Call ProcessReferences(oFileDescriptor.ReferencedFile, oDoc, oDocDef)
            Else
            Dim oComp As ComponentOccurrence
            For Each oComp In oDocDef.Occurrences
            If oComp.ReferencedDocumentDescriptor.ReferencedFileDescriptor.FullFileName = oFileDescriptor.FullFileName Then
            MsgBox (oFileDescriptor.FullFileName & vbCrLf & oFileDescriptor.RelativeFileName)
            'oComp.Delete
            Next oComp
        Next
End Sub
Markus Schrepfer
Message 4 of 8
A.Acheson
The step file just contains a solid body part and there was no errors opening. I got no assembly. Was the part attached what you were expecting?
Regards
Alan
Message 5 of 8
m.schrepfer
The step file is correct. The error occurs as I load the assembly (look at my 1st post WORK-01-xxx-xxxxxxxx-D08-000.iam). At this point the message appears, that the reference to the step file is missing. In the next step I copied the step file into the location where expected and everthing works fine. But I must delete this reference in order to check the assembly into our PLM.
Markus Schrepfer
Message 6 of 8
A.Acheson
This was a tricky one but I think I solved it with a combination of posts.
  1. First you need to resolve the assembly with the current step file.
  2. Then do a copy and reuse of the assembly using this post for work flow
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Inven...
     3. Use the below rule to expose the underlying OLEFileDescriptor.
https://forums.autodesk.com/t5/inventor-customization/ilogic-remove-unresolved-ole-links/td-p/681367...
Sub Main()
	Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oOLEFileRef As ReferencedOLEFileDescriptor
	For Each oOLEFileRef In oDoc.ReferencedOLEFileDescriptors
		oOLEFileRef.BrowserVisible = True
	Next
	MsgBox("Rule Complete!",,"iLogic")
End Sub
Then Delete the reference.
Hopefully That works for you.
Regards
Alan
Message 7 of 8
m.schrepfer
Hi @A.Acheson ,
thank you for support - I´ll test your solution and come back soon!
Markus Schrepfer
Message 8 of 8
m.schrepfer
@A.Acheson
Your solution works fine.
I´d only to make step 1 und step 2. After step 2 the references are displayed under Tools tab -> Options panel -> Links and I was able to delete the link.
Thank you for support!!!
Markus Schrepfer
