ilogic remove unresolved OLE links
louis.seguin
louis.seguin
I have had trouble finding code that removes only unresolved OLE links on any inventor document. finally got one to work. thought i'd share.
coded on Ilogic Inventor 2014. I'm not a professional coder, feel free to correct syntax
SyntaxEditor Code Snippet
ThisApplication.SilentOperation = True
 Dim oPartDoc As Document = ThisDoc.Document
 Dim bSaveDoc As Boolean = False
 Dim oRefOleFileDesc As ReferencedOLEFileDescriptor
 If oPartDoc.ReferencedOLEFileDescriptors.Count > 0 Then
     For Each oRefOleFileDesc In oPartDoc.ReferencedOLEFileDescriptors
          'Debug.Print oRefOleFileDesc.ReferenceStatus
          If oRefOleFileDesc.ReferenceStatus() = 49668 Then
          '49668 = kMissingReferencE
             'Debug.Print (oRefOleFileDesc.DisplayName)
              oRefOleFileDesc.Delete
              oPartDoc.Dirty = True
              bSaveDoc = True
        Next oRefOleFileDesc
      If bSaveDoc = True Then
          oPartDoc.Save
          bSaveDoc = False
' Be sure to set this back to False
 ThisApplication.SilentOperation = False
MechMachineMan
Here's an alternative that just opens the files with broken links, and allows the user to delete or resolve manually.
The intent is to open a top level file, skip all unresolved links, then run this. Works good for FEA files.
Sub Main()
	Dim oDoc As Document = ThisApplication.ActiveDocument
	For Each oOLEFileRef In oDoc.ReferencedOLEFileDescriptors
		oOLEFileRef.BrowserVisible = True
	Next
	For Each oSubDoc As Document In oDoc.AllReferencedDocuments
		If oSubDoc.ReferencedOLEFileDescriptors.Count > 0
			OpenAndMakeOLEVisible(oSubDoc)
	Next
	MsgBox("Rule Complete!",,"iLogic")
End Sub
Sub OpenAndMakeOLEVisible(oDoc As Document)
'This boolean can be changed in case you want all files with OLE refs open. Dim oOpenOnlyMissing As Boolean = True
oVisiDoc = ThisApplication.Documents.Open(oDoc.FullFileName,False) For Each oOLEFileRef In oVisiDoc.ReferencedOLEFileDescriptors oOLEFileRef.BrowserVisible = True If oOLEFileRef.ReferenceStatus <> ReferenceStatusEnum.kMissingReference And oOpenOnlyMissing = True oVisiDoc.ReleaseReference Else ThisApplication.Documents.Open(oVisiDoc.FullFileName,True) End If Next End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
fce
Hello there,
it is a really helpful iLogic.
How would you delete the unresolved OLEs links?
Greetings,
Francisco
dusan.naus.trz
