Sketchblockcolor
Sketchblockcolor
Message 1 of 12
Sketchblockcolor
I am trying to set the sketchblock layer color to red  in a part. What am i doing wrong??
Here is the code:
oline=ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchBlockFilter,"Select a SketchBlock")
oBlock01=oline.ContainingSketchBlock
Dim oColor As Color
oColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
oBlock01.Color.Setcolor=oColor
change
Replies (11)
Message 2 of 12
bradeneuropeArthur
 Think you should do that curve by curve!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 12
Ok, so how do you change the color of a simple line in a sketch? Keep in mind i am not talking about drawing documents but sketches in parts.......
Message 4 of 12
frederic.vandenplas
Hi @Anonymous
Please try this code (assuming it's ilogic)
Select a sketchblock in an active sketch and run the code below
If ThisApplication.ActiveDocument.SelectSet.Count = 1 Then
If ThisApplication.ActiveDocument.SelectSet.Item(1).Type = kSketchBlockObject Then
Dim oSketchBlock As SketchBlock
oSketchBlock = ThisApplication.ActiveDocument.SelectSet.Item(1)
oSketchBlock.Color = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
Else
MessageBox.Show( "Please select a sketchblock")
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Message 5 of 12
I tried the code  but i get this error
Message 6 of 12
frederic.vandenplas
Here it works inventor 2019 make sure in the options that you don't use straight vb code.
In inventor 2015 this does not seems to work, so maybe api in your current version is not supported?
Message 7 of 12
Sergio.D.Suárez
There is a problem with the selection, this code is working but you must select the block from the browser, in the model tab inside the blocks folder that appears on the left
Dim oBlock As Inventor.SketchBlockDefinition
oBlock = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchBlockDefinitionFilter, "Select a SketchBlock in Browser")
Dim oColor As Color
oColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0) 'Red
oBlock.Color = oColor
InventorVb.DocumentUpdate()
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 8 of 12
frederic.vandenplas
Hi @Sergio.D.Suárez
Now i see that you use the sketchblockdefinition instead of the blockdefinition
Try this but you still must select it in the treeview
oBlock = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchBlockFilter, "Select a SketchBlock in Browser")
Dim oColor As Color
Message 9 of 12
frederic.vandenplas
@Sergio.D.Suárez
With this code you can select in the sketch itself.
Dim oBlock As Inventor.SketchLine
Dim oColor As Color
oBlock.Parent.Color = oColor
Message 10 of 12
bradeneuropeArthur
this will change the blockcolor in the definition:
Public Sub ChangeBlockColor()
Dim a As Application
Set a = ThisApplication
Dim prt As PartDocument
Set prt = a.ActiveDocument
Dim comps As SketchBlockDefinitions
Set comps = prt.ComponentDefinition.SketchBlockDefinitions
Dim skbd As SketchBlockDefinition
Set skbd = comps.Item(1)
Dim x As Byte Dim y As Byte Dim z As Byte x = 100 y = 100 z = 100 Dim oColor As Color Set oColor = ThisApplication.TransientObjects.CreateColor(x, y, z) skbd.Color = oColor prt.Update End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 12
Thank you all for the help. This is the final working version of the code i have decided on. This way I can select the block in the sketch and not in the browsernode to change the color
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim oBlocks As SketchBlockDefinitions
oBlocks  = oDoc.ComponentDefinition.SketchBlockDefinitions
oline = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchBlockFilter, "Select a SketchBlock")
For i=1 To oBlocks.count
    If InStr(1,oBlock01.Name ,oBlocks.item(i).Name) > 0 Then
        skbd = oBlocks.Item(i)
        Dim oColor As Color
        skbd.Color = oColor
Next
Message 12 of 12
Sergio.D.Suárez
Dim oColor As Color
Dim oblockname As String
oblockname = Left(oline.ContainingSketchBlock.name, InStr(oline.ContainingSketchBlock.name, ":") - 1)
Dim oSketchBlock As Inventor.SketchBlockDefinition
For Each oSketchBlock In  oDoc.ComponentDefinition.SketchBlockDefinitions
	If oSketchBlock.name = oblockname Then
	oSketchBlock.Color = oColor
Next
 another form of code greetings
Mechanical Designer
