Override a shortcut used by a built-in command using API
DRoam
Mentor Mentor
DRoam
If I go to Customize --> Keyboard tab, find the "Line" command, and try to set its shortcut to "Ctrl+Shift+L", I'm told that "Ctrl+Shift+L" is currently assigned to "Loft [Sketched Features]", and I can click "Yes" to override and take the assignment from the Loft command.
I'm trying to figure out how to do the same thing but through the API.
I can use the following snippet to set the line command's shortcut to something like "Ctrl+L", or "Ctrl+Alt+L":
Dim oLineDef As Inventor.ControlDefinition = ThisApplication.CommandManager.ControlDefinitions("SketchLineCmd")
oLineDef.OverrideShortcut = "Ctrl+Shift+L"
However, when I try to set it to Ctrl+Shift+L, I get an error. Presumably because the shortcut belongs to the Loft command.
I tried preceding the code above with this, to remove the Ctrl+Shift+L shortcut from Loft first:
Dim oLoftDef As Inventor.ControlDefinition = ThisApplication.CommandManager.ControlDefinitions("PartLoftCmd")
oLoftDef.OverrideShortcut = "LO"
... and it does change the shortcut shown for Loft in the Customize dialog, but apparently, Ctrl+Shift+L is still tied to the loft command under the hood. So the assignment of Ctrl+Shift+L to the line command still fails.
How can I completely unassign Ctrl+Shift+L from the Loft command using the API, so that I can assign it to the Line command using the API?
bradeneuropeArthur
what do the messageboxes show?
Public Sub shortcut()
Set oLineDef = ThisApplication.CommandManager.ControlDefinitions("SketchLineCmd")
'oLineDef.OverrideShortcut = "Ctrl+Shift+L"
MsgBox oLineDef.DefaultShortcut
Set oLoftDef = ThisApplication.CommandManager.ControlDefinitions("PartLoftCmd")
'oLoftDef.OverrideShortcut = "LO"
MsgBox oLoftDef.DefaultShortcut
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
DRoam
Loft's "DefaultShortcut" is "LO", according to the API. Which is odd because it's actually not, it's "Ctrl+Alt+L".
Line's "DefaultShortcut" is blank, according to the API. Which is also odd because it's actually "L".
I can't find method or property of the ControlDefinition for Loft that is aware of the assignment to Ctrl+Alt+L, or can de-assign it. Surely I'm missing something...
