Sketch Driven Pattern takes too much time or hangs to generate multiple work points
equicad
equicad
Hi Everyone,
I observed that sketch driven pattern takes too much time or hangs during generation of work points. I followed the below processes
a) Create a sketch with number of points (more than 1000) in XY plane.
b) Create a work point in one of the points on the sketch.
c) Click on sketch driven pattern, select the sketch and work point (as feature) then click OK.
Now it is saying "executing the sketch driven pattern" and taking much time (more than 20 minutes) to complete the task.
Is there any other way around to solve it or any other process to get the same result?
Thanks in advance to everyone.
Regards
Kaushik Biswas
Equicad Solution LLP
Innovation with Automation
bradeneuropeArthur
This is in generally related to using patterns.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
