Inventor model tree structure
dhanshri_gavas
dhanshri_gavas
I wanted to create a multilevel tree structure for the model using an API. For creating the structure of the subassembly, I added the default template. and in those added parts. but in that subassembly, I wanted assembly again, but I am not able to insert the same template again, getting the error.
Document _document = inventorApp.ActiveDocument;
            AssemblyDocument pDoc = _document as AssemblyDocument;
            AssemblyComponentDefinition oPartCompDef = pDoc.ComponentDefinition;
            inventorApp.PartOptions.EnableConstructionEnvironment = false;
            pDoc.ObjectVisibility.Sketches = true;
            ObjectCollection oBodies = inventorApp.TransientObjects.CreateObjectCollection();
            TransientGeometry transientGeometry = inventorApp.TransientGeometry;
            Matrix matrix = transientGeometry.CreateMatrix();
            ComponentOccurrence derivedAssemblyOccurrence = oPartCompDef.Occurrences.Add("D:\\DemoImp\\DemoImp\\Standard.iam", matrix);
            derivedAssemblyOccurrence.Name = "SubAssembly1";
            ComponentOccurrence derivedAssemblyOccurrence_new1 = derivedAssemblyOccurrence.Definition.Occurrences.Add("D:\\DemoImp\\DemoImp\\Standard.iam", matrix);
            derivedAssemblyOccurrence_new1.Name = "SubAssembly2";
            ComponentOccurrence derivedAssemblyOccurrence_new2 = derivedAssemblyOccurrence_new1.Definition.Occurrences.Add("D:\\DemoImp\\DemoImp\\Standard.iam", matrix);
            derivedAssemblyOccurrence_new2.Name = "SubAssembly3";
Michael.Navara
The issue is in bad usage of Occurrences.Add method. The first argument of this method requires file name of existing file, not a template. In your case you try to insert the document to itself.
You need to create document from template first and then you can place the newly created document to the assembly.
Try this modified code
AssemblyDocument asmDoc = _document as AssemblyDocument;
AssemblyComponentDefinition asmCompDef = asmDoc.ComponentDefinition;
asmDoc.ObjectVisibility.Sketches = true;
var asmTemplate = "D:\\DemoImp\\DemoImp\\Standard.iam";
var subAssy1 = inventorApp.Documents.Add(DocumentTypeEnum.kAssemblyDocumentObject, asmTemplate, false) as AssemblyDocument;
ComponentOccurrence derivedAssemblyOccurrence = asmCompDef.Occurrences.AddByComponentDefinition(subAssy1.ComponentDefinition as ComponentDefinition, matrix);
var subAssy2 = inventorApp.Documents.Add(DocumentTypeEnum.kAssemblyDocumentObject, asmTemplate, false) as AssemblyDocument;
ComponentOccurrence derivedAssemblyOccurrence_new1 = derivedAssemblyOccurrence.Definition.Occurrences.AddByComponentDefinition(subAssy2.ComponentDefinition as ComponentDefinition, matrix);
var subAssy3 = inventorApp.Documents.Add(DocumentTypeEnum.kAssemblyDocumentObject, asmTemplate, false) as AssemblyDocument;
ComponentOccurrence derivedAssemblyOccurrence_new2 = derivedAssemblyOccurrence_new1.Definition.Occurrences.AddByComponentDefinition(subAssy3.ComponentDefinition as ComponentDefinition, matrix);
