see if a part is created by DesignSpring
i know that there is an iProperty where you can check, if a part is a contentcenter part.
is there a similar method to check if a part is created by DesignSpring?
Thank you
MrSmithtastic
You could try using something along these lines.
Dim oCompDef As ComponentDefinition
if oCompDef.Document.FullDocumentName.Contains("Spring") Then
do something
end if
Obviously some more code will be needed to get the Component Definition, but you get the idea?
philip1009
Another way to check is possibly by Document SubType, here's a rule that will tell you the SubType as a GUID code for each referenced part and sub-assembly in an assembly:
SyntaxEditor Code Snippet
For Each oDoc As Document In ThisDoc.Document.AllReferencedDocuments
	MessageBox.Show(CStr(oDoc.SubType), oDoc.DisplayName)
Next
If the spring part comes up as a different GUID code than every other document in the assembly then this is a viable code to check.  For example here's a sample code I use to check if a part is a sheet metal part:
If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
 If this doesn't work for you, let us know and we'll find another method to single out spring parts.
Hi and thank you for the answer.
This is not exactly what I’m looking for. When I look for “sheet metal” as sub type I think it is possible to find a lot of parts in a big assembly, but I inly want to identity the springs created by the assistant. I saw, that they have another symbol in the model browser- so perhaps there is a way to identify them.
Thank you
bradeneuropeArthur
Public Sub seeifapartiscreatedbyDesignSpring()
Dim a As Application
Set a = ThisApplication
Dim b As Document
Set b = a.ActiveDocument
Dim prs As PropertySet
For Each prs In b.PropertySets
Debug.Print prs.DisplayName
Next
If b.PropertySets.Item("FDesign").DisplayName = "FDesign" Then
MsgBox "this is a spring created with springdesign"
End If
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Thank you! Thats working.
But can you say me what FDESIGN means?
Thanks a lot
bradeneuropeArthur
Could you please mark this topic as solve for administrative reasons?
The name is chosen by Autodesk and makes it possible to add specific properties to this kind of products.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
