Save as pdf but i want also the rule to delete older pdf files
Charlies_3D_T
Message 1 of 8
Charlies_3D_T
I'm working on a code that creates a pdf file from a drawing but in that name has to be the part number and description. If i change the number or the description the rul has to delete the older pdf first and save a new one with the new name.
ThisDrawing.Document.SaveAs(oFolderParts & "\" & PartNumber & "_" & PartDescription & "_REV_" & iProperties.Value("Project","Revision Number") & ".pdf", True)
Any one has done this before?
Replies (7)
Message 2 of 8
Jesper_S
Hi.
I have been using this iLogic.
It doesn't delete the PDF files, it moves them to a folder called Obsolete.
Imports System.Windows.Forms
' Get current location of this file
'Dim ExportPath As String = ThisDoc.Path
Dim ExportPath As String = "G:\Order kund\"
'query user
question = MessageBox.Show("Is a .PDF Export Required?", iProperties.Value("Project", "Part Number"),MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'set condition based on answer
If question = vbYes Then
' Define folder browse dialog
Dim Dialog = New FolderBrowserDialog()
' Set options for folder browser dialog
Dialog.SelectedPath = ExportPath
Dialog.ShowNewFolderButton = True
Dialog.Description = ("Choose Folder for Export Dwg ") & iProperties.Value("Project", "Part Number")
' Show dialog box
If DialogResult.OK = Dialog.ShowDialog() Then
	' User clicked 'ok' on dialog box - capture the export path
	ExportPath = Dialog.SelectedPath '& "\"
Else
	' User clicked 'cancel' on dialog box - exit
	Return
End If
'------PDF Setup-------
oPath = ExportPath
oFileName = iProperties.Value("Project", "Part Number")
oRevNum = iProperties.Value("Project", "Revision Number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 0
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
oOptions.Value("Custom_Begin_Sheet") = 1
oOptions.Value("Custom_End_Sheet") = 10
End If
'get PDF target folder path
oFolder = oPath '& "\PDF"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
If iProperties.Value("Project", "Revision Number") = Nothing Then
 'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & ".pdf"
Else
'Set the destination file name
oDataMedium.FileName = oFolder & "\" & oFileName & _
" Rev " & oRevNum & ".pdf"
End If
Else
Return
End If
On Error Goto handlePDFLock
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
If oRevNum >= "1" Then
Dim EarlyRev As String = Chr(Asc(oRevNum) - 1)
Dim FileCurrent As String = oPath & PDF_Folder & "\" & oFileName & " Rev " & EarlyRev & ".pdf"
Dim FileObs As String = oPath & PDF_Folder & "\OBSOLETE\" & oFileName & " Rev " & EarlyRev & ".pdf"
Dim oObs As String = oPath & "\OBSOLETE\"
If Not System.IO.Directory.Exists(oObs) Then
   System.IO.Directory.CreateDirectory(oObs)
End If
If System.IO.File.Exists(FileCurrent) = True Then
System.IO.File.Move(FileCurrent, FileObs)
Else
'If System.IO.File.Exists(Fileobs) = False Then
'MessageBox.Show("Revision " & EarlyRev & " is missing!", "iLogic")
'End If
End If
End If
Exit Sub
handlePDFLock:
MessageBox.Show("PDF not created, most likely someone else has it open.", "No PDF for you " & ThisApplication.GeneralOptions.UserName & "!")
Resume Next
'Show message box
MessageBox.Show("Drawing saved and PDF Exported to LAST EDITED document folder/PDF", "Save I-logic")
'------end of iLogic-------
You can use it as a base and perhaps change some of the code.
Perhaps change this
to this
System.IO.File.Delete(FileCurrent, FileObs)
Dont know if it will work buts it's an idea.
//Jesper
Message 3 of 8
Charlies_3D_T
@Jesper_S
Thank you! But my problem is that my name could change if i change the number. So in one way or an other i need to save the old name and first search for it and delete it if it's not the same as a new name.
That's my problem.
Message 4 of 8
bradeneuropeArthur
maybe this way:
If System.IO.File.Exists(oFolderParts & "\" & PartNumber & "_" & PartDescription & "_REV_" & iProperties.Value("Project","Revision Number") & ".pdf") = True Then
System.IO.File.Delete(oFolderParts & "\" & PartNumber & "_" & PartDescription & "_REV_" & iProperties.Value("Project","Revision Number") & ".pdf", FileObs)
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 5 of 8
tom.quinzi
Observer
Observer
But excuse my ignorance, how do I get Vault to run this rule?
Tom
Message 6 of 8
bradeneuropeArthur
You need to create a "Custom Job " for Vault-Extension for this.
Than you need to add this job as a Custom job to any Lifecycle change event.
If correctly done the jib will run and do its tasks.
Seems to be simple but it is a little more complex than these three lines....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 8
tom.quinzi
Observer
Observer
Ok thanks for your reply.
Do I need coolOrange to run these custom scripts?
Tom
Message 8 of 8
bradeneuropeArthur
No, you don't need that.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
