Save and replace with iLogic
Hello
ist there a way to save and raplece external file with i Logic
To frist save in one name and the replace with another
'get the part
part = Component.InventorComponent("Glashalter mittig:1")
'open the part
doc = ThisApplication.Documents.Open(part.Definition.Document.FullDocumentName)
'oPath = ThisDoc.Path & "\"
' save the part as step
' doc.SaveAs(oPath & "Glashalter mitte position_" & Position & ".stp" , True)
doc.SaveAs("C:\Users\Aleksandar.Jovicic\Desktop\FGL\Steps\Glashalter mitte.stp" , True)
doc.Replace("Glashalter mitte.stp", "Glashalter mitte " & Position &".stp", True)
' close the part
doc.Close()
MechMachineMan
wat
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
What do you mean wat?
Files or?
