Attach a folder to email
Is there a VBA/iLogic code to attacht a folder (all files in that folder) in a e mail?
rossano_praderi
This sample works only with the microsoft frameworks 4.5 and above.
AddReference "F:\Progetti\Inventor\Progetti_2015\Compressione\dll\InvMyZip.dll" ' change the path with the correct dll location
Sub Main
	cFolder = "f:\TestZip" ' the folder to compress
	oZip = "f:\TestZip.zip" ' compressed file location and name
Dim CompressFolder As New InvMyZip.InvMyZip
	CompressFolder.oZip(cFolder, oZip)
	If System.IO.File.Exists(oZip) Then
		SendMail("spam@dshortway.com", "SendMail Ilogic Rule Test Message", oZip, _
				"Test message from Ilogic rule SendMail" & vbCr _
					& "With multiline text in the body message!")
CompressFolder = Nothing
End Sub
Private Sub SendMail(ToAdress as String, tSubject As String, aFile As String, tBody As String)
Dim OlApp As Object = CreateObject("Outlook.Application")
Dim eMail As Object = OlApp.CreateItem(0)
	With eMail
		.To = ToAdress
		.Subject = tSubject
		.attachments.Add(aFile)
		.Body = tBody
		.Display
		'.Mail.Send ' uncomment this line if you want send your message immediately
	End With
OlApp = Nothing
eMail = Nothing
End Sub
This sample and the attached files have to be considered "as is".
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Than you Rossano!!!
it works
rossano_praderi
Mark as solution, please.
