Runtime Error with VBA Code
Message 1 of 13
I'm having a bit of a problem with the SaveAs call in this piece of code. Everything else is working fine and the needed paths are getting passed to the sub.  The SaveAs bit is returning a runtime error. Any advice is greatly appreciated as I wade through this very small part of a larger problem. Thanks!
Sub SaveNew(fPath)
    'declare the new assembly
    Dim newAsm As AssemblyDocument
    'set the assembly to the target assembly
    Set newAsm = ThisApplication.Documents.Open(fPath, False)
    'save as on the target assembly - passed from GetPath()
    newAsm.SaveAs newPath, False
    'close the target assembly
    newAsm.Close (False)
Replies (12)
Message 2 of 13
bradeneuropeArthur
Newpath is not declared
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 13
Thanks, but what isn't showing is the rest of my code. newPath is global.
Public newPath As String
Public filePath As String
Public Sub PlaceCompartment()
    'get the object from the active document
    Dim asmDoc As AssemblyDocument
    Set asmDoc = ThisApplication.ActiveDocument
    'on run, display the different options with a GUI and buttons - also sets the filepath to the desired assembly file
    AsmForm.Show
    'get new path
    Call GetPath
    'perform save as of needed assembly and parts
    Call SaveNew(filePath)
    'replace new assembly components with newly created components
    'ComponentReplace(
End Sub
Public Function GetPath() As String
    'set up the dialog
    Dim fileDlg As FileDialog
    'create file dialog object
    Call ThisApplication.CreateFileDialog(fileDlg)
    'define filter
    fileDlg.Filter = "Inventor Files (*.iam)|*.ipt | Assembly File (*.iam)|*.iam"
    'define the part and assembly files filter to be the default filter
    fileDlg.FilterIndex = 1
    'file dialog title
    fileDlg.DialogTitle = "Save File As"
    'throw error when user hits cancel
    fileDlg.CancelError = True
    'show file dialog
    On Error Resume Next
    fileDlg.ShowSave
    newPath = fileDlg.FileName
End Function
Sub SaveNew(fPath)
Message 4 of 13
bradeneuropeArthur
Your new name already exist....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 13
@bradeneuropeArthur
I'm not really following. Can you be more descriptive than "your new name already exists"? Not at all trying to be jerk, I just don't understand what you're trying to tell me. The variable newPath already exists? The newly created AssemblyDocument exists? If the variable, I'm not exactly sure what the problem is - it is declared globally and updated along the way to the SaveNew sub (the file path it contains within SaveNew() is correct from GetPath()). Even if I change it to a literal path, I still get the runtime error.
Message 6 of 13
bradeneuropeArthur
You select a file in a filedialog. So I think assume the file exist
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 13
I don't select anything in the file dialog. I only browse to where I want abd create the path that is used for the save as. File fialog doesnt create anything new, it just returns a string.
Message 8 of 13
bradeneuropeArthur
Hi.
I assume or am I not correct with:
The file is already there, so an existing file?
Or am I wrong.
Understand what I mean
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 13
There is no file there. It is simply a text string holding what I want the file to be named. It's a save dialog box, not an open and it doesn't actually save anything, hence no file.
Message 10 of 13
bradeneuropeArthur
What happens if you fill in the newpath as string like c:\test.iam?
Does it work than?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 13
bradeneuropeArthur
Hi Found I think:
The filedialog always saves as .ipt
look in the messagebox
    'set up the dialog
    'define filter
    fileDlg.Filter = "Inventor Files (*.ipt)|*.ipt | Assembly File (*.iam)|*.iam"
'OPTION SULUTION:
'fileDlg.Filter = "Inventor Files (*.iam)|*.iam ' THIS WILL FUNCTION ONLY FOR ASSEMBLIES 'OPTION SULUTION:
'define the part and assembly files filter to be the default filter fileDlg.FilterIndex = 1 'file dialog title fileDlg.DialogTitle = "Save File As" 'throw error when user hits cancel fileDlg.CancelError = True 'show file dialog On Error Resume Next fileDlg.ShowSave newPath = fileDlg.FileName MsgBox newPath ' RESULT ALWAYS *.IPT End Function
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 13
I was literally just typing up the same thing! I realized it when I sat down at my desk this morning and it works perfectly fine now. Thanks for the help!
Message 13 of 13
bradeneuropeArthur
My pleasure to help.
Your thanks are appreciated.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
