Edit Driven Dimension????
I need to know how to delete or move driven dimensions generated by operations like patterns in a sketch, the driven dimensions make the  very messy sketch.
It's possible?. Or maybe change the visibility?
YuhanZhang
You can turn off the "Dimension Visibility" in the context menu of a 2D/3D sketch also via API use PlanarSketch/Sketch3D.DimensionsVisible property. Also you can delete them if you need not them via API, you can check DimensionConstraint.Driven and then call DimensionConstraint.Delete if they are driven dimensions.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
bradeneuropeArthur
Please use this piece of code:
Public Sub dimvis()
Dim a As Application
Set a = ThisApplication
Dim b As PartDocument
Set b = a.ActiveDocument
Dim c As Sketch
Set c = b.ComponentDefinition.Sketches(1)
For Each d In c.DimensionConstraints
If d.Driven = True Then
d.Delete
Next
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
