Run the SketchProjectCutEdgesCmd from top level assembly
Hello everybody,
I need some help with the following issue.
I wrote a rule wich generally works fine.
-The rule checks in wich direction the part is in the workspace, and create a new sketch.
-rename the sketch to identify
-create a iProperty for the edgelenght of the projected edges, measure the value, and set to the iProperty
-close and delete the sketch.
If i fire the rule in the part...everything works
If i fire the rule as a external rule in the part...everything works
But
if i fire the rule from the assembly (run rule in component comand) then the edges will not be projected and the rule stops working.
the same if i fire the rule as an external rule from top level assembly
I need this for cuting time calculation of the hole assembly, so later i add all the loops measured an have a time for the cuttind duration of all the parts. 😉
Any help would be great!
I m sure the error occures in the control definition of the project comand, but i dont know how and why!
I add a simple assembly for demonstrating the problem as zip.
Simon
SyntaxEditor Code Snippet
'Set all to Zero
iProperties.Value("Custom", "X")=Round(Measure.ExtentsLength)
iProperties.Value("Custom", "Y")=Round(Measure.ExtentsWidth)
iProperties.Value("Custom", "Z")=Round(Measure.ExtentsHeight)
iProperties.Value("Custom", "Loop")=0
iProperties.Value("Custom", "Loop_SETM")=0
iProperties.Value("Custom", "Loop_SELM")=0
Dim opartDoc As Inventor.PartDocument
opartDoc = ThisDoc.Document
' Set a reference to the part component definition.
Dim oCompDef As PartComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
' Create a new sketch on plane`
'Get the orientation Of the Part_______________________XYZ
If MinOfMany(iProperties.Value("Custom", "X"),iProperties.Value("Custom", "Y"),iProperties.Value("Custom", "Z"))=iProperties.Value("Custom", "Z") Then
n=3
Else If MinOfMany(iProperties.Value("Custom", "X"),iProperties.Value("Custom", "Y"),iProperties.Value("Custom", "Z"))=iProperties.Value("Custom", "Y") Then
n=2
Else If MinOfMany(iProperties.Value("Custom", "X"),iProperties.Value("Custom", "Y"),iProperties.Value("Custom", "Z"))=iProperties.Value("Custom", "X") Then
n=1
End If
Dim oSketch1 As PlanarSketch
oSketch1 = oCompDef.Sketches.Add(oCompDef.WorkPlanes.Item(n))
'edit the Sketch
oSketch1.Edit
' Set a reference To the transient geometry Object.
Dim oTransGeom As TransientGeometry
oTransGeom = ThisApplication.TransientGeometry
'project cut edges
Dim oDef As ControlDefinition
oDef = ThisApplication.CommandManager.ControlDefinitions.Item("SketchProjectCutEdgesCmd")
oDef.Execute
'close Sketch
oSketch1.ExitEdit
'Rename the Sketch To identify
oSketch1.Name = "Temp_Loop"
'Write the Loop To the iproperty
iProperties.Value("Custom", "Loop")=Measure.Perimeter("Temp_Loop")
RuleParametersOutput()
'delete the Sketch
oSketch1.Delete
opartDoc.Update()
InventorVb.DocumentUpdate()
MechMachineMan
From what I can remember during a brief stint with using Project cut edges, I think you need to open the part for edit if you are projecting the cut edges into a part, and also select the occurrences with edges to project before running the command.
Good luck.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Hello MechMachine,
Thanks for reply, but the SketchProjectCutEdgesCmd works.
The rule crates the curves, measure the value and save it to the iProperty.
My problem is that i cant run the rule as external (or run rule in component comand) from an Assembly
Any Idea?
MechMachineMan
Hmm Yes. Makes sense.
It would be failing at the bolded line because what ThisDoc.Document returns in the italicized line would be an Inventor.AssemblyDocument type.
You need to put in more error proofing in the code and expand upon the logic of how its supposed to work.
'Set all to Zero
n=3
n=2
n=1
End If
'edit the Sketch
oSketch1.Edit
'project cut edges
oDef.Execute
'close Sketch
oSketch1.ExitEdit
'delete the Sketch
oSketch1.Delete
opartDoc.Update()
I would try my luck with it modified as below.
'Set all to Zero
Dim oDoc As Inventor.Document
oDoc = ThisApplication.ActiveDocument
' Set a reference to the component definition.
Dim oCompDef As ComponentDefinition
oCompDef = oDoc.ComponentDefinition
n=3
n=2
n=1
End If
'edit the Sketch
oSketch1.Edit
'project cut edges
oDef.Execute
'close Sketch
oSketch1.ExitEdit
'delete the Sketch
oSketch1.Delete
oDoc.Update()
Justin K
^^^^Thanks Mech machine, but does not work
Ok,
After dealing with the API modell i  found the solution by my own.
I Think the problem was that i used the transient geometry wich is in "this Application"
Now i use the  "SurfaceBodies" of the "Part component definion" for my Geometry.
I also dont use the control definition, i use the ProjectedCuts comand of the planar sketches definition
What ever, it works! May someone can explain me why?
I can fire the rule....in the part,
..............................as external rule in the part
..............................from assembly in the part,
..............................from assembly as external rule in the part
So everything is fine!
Thanks!
'Set all to Zero
Dim oPartDoc As PartDocument
oPartDoc =  ThisDoc.Document
n=3
n=2
n=1
End If
'edit the Sketch
oSketch1.Edit
' Set a reference To BODY of the PART wich i m workin with.
 Dim SBody As SurfaceBodies
 SBody = oCompDef.SurfaceBodies
'Project the cuts Not the cut edges
oSketch1.ProjectedCuts.Add()
'Exit
oSketch1.ExitEdit
'delete the Sketch
oSketch1.Delete
oPartDoc.Update
The error is where MM Stated:
 When a rule is run from an assembly the  (ThisDoc) is an assembly document. Not a part document.
You need to traverse the assembly to get to the sub components/occurrences.
'____Iteration Template for Assembly Structures_______
Sub Main()
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    Call Iterate(oAsmDoc.ComponentDefinition.Occurrences, 1)
End Sub
Private Sub Iterate(Occurrences As ComponentOccurrences, Level As Integer)
''Iterate through Assembly Occurrences
    Dim oOcc As ComponentOccurrence
    Dim sName As String
    For Each oOcc In Occurrences
    ''Find Parts in Assembly
        sName = oOcc.Name
        Try
        'Investigate Occurence and 'Do Something'
            Select Case oOcc.DefinitionDocumentType
                Case kAssemblyDocumentObject
                    ''Do something to an Assembly
                Case kPartDocumentObject
                    ''Do something to a Part
                Case kForeignModelDocumentObject
                Case kSATFileDocumentObject
                Case kNoDocument
                Case Else
                    ''Do something if an object is misidentified
            End Select
        Catch ex As Exception
        'MsgBox("There was an Error! --" & ex.Message)
        Finally
        ''Run through the sub assemblies
            If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
                Call Iterate(oOcc.SubOccurrences, Level + 1)
            End If
        End Try
    Next
End Sub
