Run multiple rules via one rule
Instead of having to run each rule individually, is it possible to run mutiple rules via one rule?
So that I just have to run that one rule, which will then run the others?
JhoelForshav
Yes,
iLogicVb.RunRule("Rule name")
Check out
iLogicvb.Automation
 for functions like this
If it's an external rule, do I then still use
I'm asking, cause after I moved my local to external rules, this isn't working anymore
JhoelForshav
Then you should use:
iLogicVB.RunExternalRule("rulename")
