Inventor 2020 Barebones Deployment Size on HDD
If I remember correctly, when I installed AI 2020, the web installer had a 12 gig download.
What is the bare minimum size for deployment?
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try suggestions in below link.
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/System-requirements-for-Autodesk-Inventor-2020.html
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Hi Chandra,
That link describes min and recommended spec.
I am after the minimum setup file size for inventor after stipping non-critical components of AI
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
After stipping non-critical components of AI, Install shield window or dialog will show minimum memory required.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Sorry CS, perhaps I have not made myself clear.
My concern is the final downloadable file size for my OEM solution. Once I have customized and rebranded the product what would be the downloadable file size. lets say we have the installation folder and sub-folders and after removing all non-crit components and compressed the root install folder, what would be the size?
YuhanZhang
Do you mean the total file size of the product(installer for your customers) you created bases on Inventor OEM? Can you let me what configuration you set for the product in the Inventor OEM Configurator? As I just have an Inventor OEM 2019 at hand and a product bases on it, the product is 6.32 GB, I think the Inventor OEM 2020 has similar size when you create your product from it.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
