Hi @ekinsb , i am working on a different macro that works in assemblies instead of drawing.
The macro works well. I change your macro for drawings (Thanks for your work).
The macro should for each assemblies in a folder:
- Select a folder
- open .iam in that folder
- export BOM
- close .iam
The macro works well on the first .iam, but on the next .iam, something goes wrong.
I try to understand what goes wrong, by debug but...i didnt find the matter.
Thanks in advance.
Here's the code:
Public Sub ToExcel()
' Get the drawing directory to be processed
Dim txtPath As String
'txtPath = "\\SOTAWIN2\Drafting\Projects\14-07 Seaport B\Inventor\F - Frames\"
txtPath = "C:\Users\Admin\Documents\TestMacro\"
'D:\Disegni
'D:\Disegni\2007.01.28_(Cucina Mattoni)
'D:\Disegni\2013.08.29_(Scrivania)
'C:\Users\Admin\Documents
' Get all of the drawing files in the directory and subdirectories.
Dim drawings() As String
''Call GetAllFiles(txtPath, "*.idw", drawings)
Call GetAllFiles(txtPath, "*.iam", drawings)
' Iterate through the found drawings.
Dim i As Integer
For i = 0 To UBound(drawings)
Dim drawing As String
drawing = drawings(i)
''Dim drawDoc As Inventor.DrawingDocument
Dim drawDoc As Inventor.AssemblyDocument
Set drawDoc = ThisApplication.Documents.Open(drawing)
' Export parts list info to Excel
'ExportPartslisttoExcel
'BOM_Export_Pro
'Call BOM_Export_Pro
'Application.Run ("BOM_Export_Pro")
'---TEST---
'OK---Sub BOM_Export_Pro() 'Esportazione DB completo e funzionante
Dim oApp As Application
Set oApp = ThisApplication
Dim invDoc As Document
Set invDoc = ThisApplication.ActiveDocument
Dim oDocument As Inventor.Document
Set oDocument = ThisApplication.ActiveDocument
Dim invDesignInfo As PropertySet
Set invDesignInfo = invDoc.PropertySets.Item("Design Tracking Properties")
Dim invPartNumberProperty As Property
Set invPartNumberProperty = invDesignInfo.Item("Part Number")
NumeroParte = invPartNumberProperty.Value
'Dim Estensione As String
Estensione = (".csv")
Patch = GetFilePatch(oDocument.FullFileName)
PercaorsoNomeEst = (Patch & NumeroParte & Estensione)
Peso = invDoc.ComponentDefinition.MassProperties.Mass
'Data
Dim DataCmp As String
'DataCmp = (Day(Date) & "/" & Month(Date) & "/" & Year(Date))
DataCmp = Date$
'DataCmp = (Month(Date) & "/" & Day(Date) & "/" & Year(Date))
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
Set oBOM = oDoc.ComponentDefinition.BOM
' Imposta corrente il livello Principale
Dim oAsmDef As AssemblyComponentDefinition
Set oAsmDef = ThisApplication.ActiveDocument.ComponentDefinition
oAsmDef.RepresentationsManager.LevelOfDetailRepresentations.Item("Principale").Activate
If oApp.ActiveDocument.DocumentType = kAssemblyDocumentObject Then
Dim oAssyDoc As AssemblyDocument
Set oAssyDoc = oApp.ActiveDocument
Dim oAssyCompDef As AssemblyComponentDefinition
Set oAssyCompDef = oAssyDoc.ComponentDefinition
Dim excel_app As Excel.Application
' Setta la proprietà della vista strutturale al solo di primo livello
oBOM.StructuredViewFirstLevelOnly = True
' Attiva la vista strutturata della distinata componenti
oBOM.StructuredViewEnabled = True
' Crea l'applicazione Excel
Set excel_app = CreateObject("Excel.Application")
' Commenta questa linea se vuoi excel invisibile
excel_app.Visible = False
'Crea il foglio di lavoro
Call excel_app.Workbooks.Add
Dim oBomR As BOMRow
Dim oBOMPartNo As String
With excel_app
'.Range("A1").Select
'.ActiveCell.Value = "Padre"
'.Range("B1").Select
'.ActiveCell.Value = "Part Number"
'.Range("C1").Select
'.ActiveCell.Value = "Quantity"
'.Range("D1").Select
'.ActiveCell.Value = "Peso"
'.Range("R1").Select
'.ActiveCell.Value = "Inizio Validità"
'Iterate through parts only BOM View
Dim ii As Integer
For ii = 1 To oAssyCompDef.BOM.BOMViews(2).BOMRows.Count
'Set oBomR to current BOM Row
Set oBomR = oAssyCompDef.BOM.BOMViews(2).BOMRows(ii)
'Get Current Row part number from part
oBOMPartNo = oBomR.ComponentDefinitions(1).Document.PropertySets(3).ItemByPropId(5).Value
'oBOMPeso = oBomR.ComponentDefinitions(1).MassProperties.Mass
'Write values to spreadsheet
.Range("A" & ii + 1).Select
.ActiveCell.Value = NumeroParte
.Range("B" & ii + 1).Select
.ActiveCell.Value = oBOMPartNo
.Range("C" & ii + 1).Select
.ActiveCell.Value = oBomR.TotalQuantity 'Quantity value
'.Range("D" & ii + 1).Select
'.ActiveCell.Value = Format(oBOMPeso, "###.###")
Next ii
End With
Else
Exit Sub
'Ordina le righe per ordine alfabetico secondo il codice
Sheets("Foglio1").Select
ActiveSheet.Select
Columns("A:R").Select
Range("A21").Activate
ActiveWorkbook.Worksheets("Foglio1").Sort.SortFields.Clear
ActiveWorkbook.Worksheets("Foglio1").Sort.SortFields.Add Key:=Range("B2:B200") _
, SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
With ActiveWorkbook.Worksheets("Foglio1").Sort
.SetRange Range("A1:R200")
.Header = xlYes
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
End With
ActiveWorkbook.SaveAs filename:=(PercaorsoNomeEst), FileFormat:=xlCSVWindows, CreateBackup:=False, Local:=True
Application.DisplayAlerts = False
ActiveWorkbook.Close
excel_app.Quit 'Chiude definitivamente l'applicazione excel
MsgBox "La distinta è stata esportata correttamente!"
'End
'OK---End Sub
'---TEST---
'Salva il drawing.
drawDoc.Save
'Close the drawing.
drawDoc.Close (True)
Next
End Sub
Public Function GetAllFiles(path As String, searchString As String, fileList() As String)
' Get the list of files in the current directory.
Dim fileCount As Integer
On Error Resume Next
fileCount = UBound(fileList) + 1
If Err Then
fileCount = 0
On Error GoTo 0
Dim maxCount As Integer
maxCount = fileCount
Dim filename As String
filename = Dir(path & searchString, vbNormal)
Do While filename <> ""
If fileCount = maxCount Then
maxCount = fileCount + 50
ReDim Preserve fileList(maxCount - 1)
fileCount = fileCount + 1
fileList(fileCount - 1) = path & filename
filename = Dir
Loop
ReDim Preserve fileList(fileCount - 1)
' Build a list of the directories.
Dim directoryList() As String
Dim maxDirectories As Integer
maxCount = 0
Dim directoryCount As Integer
directoryCount = 0
Dim dirName As String
dirName = Dir(path, vbDirectory)
Do While dirName <> ""
If dirName <> "." And dirName <> ".." And dirName <> "OldVersions" Then
If (GetAttr(path & dirName) And vbDirectory) Then
If directoryCount = maxCount Then
maxCount = directoryCount + 50
ReDim Preserve directoryList(maxCount - 1)
directoryCount = directoryCount + 1
directoryList(directoryCount - 1) = path & dirName & "\"
dirName = Dir
Loop
' Process the subdirectories.
If directoryCount > 0 Then
ReDim Preserve directoryList(directoryCount - 1)
Dim i As Integer
For i = 0 To UBound(directoryList)
Call GetAllFiles(directoryList(i), searchString, fileList)
Next
End Function
'Funzione che estrae il percorso completo nel quale si trova il file attualmente in uso
Private Function GetFilePatch(ByVal sFullFileName As String) As String
Dim sFilePatch As String
Dim nPos1 As Integer
Dim nPosf1 As Integer
Dim nPos2 As Integer
sFilePatch = sFullFileName
nPos1 = InStrRev(sFullFileName, "\")
nPos2 = InStrRev(sFullFileName, ".")
If nPos1 > 0 Then
sFilePacth = Mid$(sFullFileName, nPos1 + 1)
nPosf1 = InStr(sFullFileName, ".")
If nPos1 > 0 Then
sFilePatch = Left$(sFilePatch, nPosf1 - (nPos2 - nPos1))
GetFilePatch = sFilePatch
End Function
Debug Error image:
