Run macro on directory of drawings
I am trying to run a macro (ExportPartslisttoExcel) on a directory of drawings.  I have started with Mod the Machine's code to print a directory of drawings to PDF.  When I copy the code to the Microsoft Visual Basic for Applications editor in Inventor I get a syntax error on the lines highlited in red.  Can anyone tell me how correct this?
Thanks in advance.
Public Sub ToExcel()
    ' Get the drawing directory to be processed
    Dim txtPath As String
    txtPath = "\\SOTAWIN2\Drafting\Projects\14-07 Seaport B\Inventor\F - Frames\"
    ' Get all of the drawing files in the directory and subdirectories.
    Dim drawings() As String = System.IO.Directory.GetFiles(txtPath, "*.idw", System.IO.SearchOption.AllDirectories)
    ' Iterate through the found drawings.
    For Each drawing As String In drawings
        Dim drawDoc As Inventor.DrawingDocument
        drawDoc = invApp.Documents.Open(Drawing)
        ' Export parts list info to Excel
        ' Close the drawing.
        drawDoc.Close (True)
    Next
End Sub
MechMachineMan
Thanks in advance.
    Dim drawings As String() = System.IO.Directory.GetFiles(txtPath, "*.idw", System.IO.SearchOption.AllDirectories)
    Next
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
No luck Justin.
I still get a syntax error.
Gary
ekinsb
The code in the post is VB.NET.  There are differences between VB.NET and VBA.  One of the big differences is the availabilty of the .NET libraries when using VB.NET.  It's very powerful and this program uses it to get all of the files.  It's quite a bit messier when using functionality built-in to VBA.  There is a file system library that can be used but for some reason I've always just tried to make do with what's built into VBA. I've written a function using built-in functionality to traverse folders and do the equivalent of the .NET GetFiles function that the original sample is using. Below is the full VBA code. I tested it on a local directory but hopefull it will work on a remote path too.
    Call GetAllFiles(txtPath, "*.idw", drawings)
    Dim i As Integer
    For i = 0 To UBound(drawings)
        Dim drawing As String
        drawing = drawings(i)
        Set drawDoc = ThisApplication.Documents.Open(drawing)
    Next
End Sub
Public Function GetAllFiles(path As String, searchString As String, fileList() As String)
    ' Get the list of files in the current directory.
    Dim fileCount As Integer
    On Error Resume Next
    fileCount = UBound(fileList) + 1
    If Err Then
        fileCount = 0
    End If
    On Error GoTo 0
    Dim maxCount As Integer
    maxCount = fileCount
    Dim filename As String
    filename = Dir(path & searchString, vbNormal)
    Do While filename <> ""
        If fileCount = maxCount Then
            maxCount = fileCount + 50
            ReDim Preserve fileList(maxCount - 1)
        End If
        fileCount = fileCount + 1
        fileList(fileCount - 1) = path & filename
        filename = Dir
    Loop
    ReDim Preserve fileList(fileCount - 1)
    ' Build a list of the directories.
    Dim directoryList() As String
    Dim maxDirectories As Integer
    maxCount = 0
    Dim directoryCount As Integer
    directoryCount = 0
    Dim dirName As String
    dirName = Dir(path, vbDirectory)
    Do While dirName <> ""
        If dirName <> "." And dirName <> ".." And dirName <> "OldVersions" Then
            If (GetAttr(path & dirName) And vbDirectory) Then
                If directoryCount = maxCount Then
                    maxCount = directoryCount + 50
                    ReDim Preserve directoryList(maxCount - 1)
                End If
                directoryCount = directoryCount + 1
                directoryList(directoryCount - 1) = path & dirName & "\"
            End If
        End If
        dirName = Dir
    Loop
    ' Process the subdirectories.
    If directoryCount > 0 Then
        ReDim Preserve directoryList(directoryCount - 1)
        Dim i As Integer
        For i = 0 To UBound(directoryList)
            Call GetAllFiles(directoryList(i), searchString, fileList)
        Next
    End If
End Function
Brian Ekins
Mod the Machine blog
Outstanding!
Thank you very much Brian.
Claudio_73
Hi @ekinsb , i am working on a different macro that works in assemblies instead of drawing.
The macro works well. I change your macro for drawings (Thanks for your work).
The macro should for each assemblies in a folder:
- Select a folder
- open .iam in that folder
- export BOM
- close .iam
The macro works well on the first .iam, but on the next .iam, something goes wrong.
I try to understand what goes wrong, by debug but...i didnt find the matter.
Thanks in advance.
Here's the code:
'txtPath = "\\SOTAWIN2\Drafting\Projects\14-07 Seaport B\Inventor\F - Frames\"
txtPath = "C:\Users\Admin\Documents\TestMacro\"
'D:\Disegni
'D:\Disegni\2007.01.28_(Cucina Mattoni)
'D:\Disegni\2013.08.29_(Scrivania)
'C:\Users\Admin\Documents
''Call GetAllFiles(txtPath, "*.idw", drawings)
Call GetAllFiles(txtPath, "*.iam", drawings)
Dim i As Integer
''Dim drawDoc As Inventor.DrawingDocument
Dim drawDoc As Inventor.AssemblyDocument
'ExportPartslisttoExcel
'BOM_Export_Pro
'Call BOM_Export_Pro
'Application.Run ("BOM_Export_Pro")
'---TEST---
'OK---Sub BOM_Export_Pro() 'Esportazione DB completo e funzionante
Dim oApp As Application
Set oApp = ThisApplication
Dim invDoc As Document
Set invDoc = ThisApplication.ActiveDocument
Dim oDocument As Inventor.Document
Set oDocument = ThisApplication.ActiveDocument
Dim invDesignInfo As PropertySet
Set invDesignInfo = invDoc.PropertySets.Item("Design Tracking Properties")
Dim invPartNumberProperty As Property
Set invPartNumberProperty = invDesignInfo.Item("Part Number")
NumeroParte = invPartNumberProperty.Value
'Dim Estensione As String
Estensione = (".csv")
Patch = GetFilePatch(oDocument.FullFileName)
PercaorsoNomeEst = (Patch & NumeroParte & Estensione)
Peso = invDoc.ComponentDefinition.MassProperties.Mass
'Data
Dim DataCmp As String
'DataCmp = (Day(Date) & "/" & Month(Date) & "/" & Year(Date))
DataCmp = Date$
'DataCmp = (Month(Date) & "/" & Day(Date) & "/" & Year(Date))
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
Set oBOM = oDoc.ComponentDefinition.BOM
' Imposta corrente il livello Principale
Dim oAsmDef As AssemblyComponentDefinition
Set oAsmDef = ThisApplication.ActiveDocument.ComponentDefinition
oAsmDef.RepresentationsManager.LevelOfDetailRepresentations.Item("Principale").Activate
If oApp.ActiveDocument.DocumentType = kAssemblyDocumentObject Then
Dim oAssyDoc As AssemblyDocument
Set oAssyDoc = oApp.ActiveDocument
Dim oAssyCompDef As AssemblyComponentDefinition
Set oAssyCompDef = oAssyDoc.ComponentDefinition
Dim excel_app As Excel.Application
' Setta la proprietà della vista strutturale al solo di primo livello
oBOM.StructuredViewFirstLevelOnly = True
' Attiva la vista strutturata della distinata componenti
oBOM.StructuredViewEnabled = True
' Crea l'applicazione Excel
Set excel_app = CreateObject("Excel.Application")
' Commenta questa linea se vuoi excel invisibile
excel_app.Visible = False
'Crea il foglio di lavoro
Call excel_app.Workbooks.Add
Dim oBomR As BOMRow
Dim oBOMPartNo As String
With excel_app
'.Range("A1").Select
'.ActiveCell.Value = "Padre"
'.Range("B1").Select
'.ActiveCell.Value = "Part Number"
'.Range("C1").Select
'.ActiveCell.Value = "Quantity"
'.Range("D1").Select
'.ActiveCell.Value = "Peso"
'.Range("R1").Select
'.ActiveCell.Value = "Inizio Validità"
'Iterate through parts only BOM View
Dim ii As Integer
For ii = 1 To oAssyCompDef.BOM.BOMViews(2).BOMRows.Count
'Set oBomR to current BOM Row
Set oBomR = oAssyCompDef.BOM.BOMViews(2).BOMRows(ii)
'Get Current Row part number from part
oBOMPartNo = oBomR.ComponentDefinitions(1).Document.PropertySets(3).ItemByPropId(5).Value
'oBOMPeso = oBomR.ComponentDefinitions(1).MassProperties.Mass
'Write values to spreadsheet
.Range("A" & ii + 1).Select
.ActiveCell.Value = NumeroParte
.Range("B" & ii + 1).Select
.ActiveCell.Value = oBOMPartNo
.Range("C" & ii + 1).Select
.ActiveCell.Value = oBomR.TotalQuantity 'Quantity value
'.Range("D" & ii + 1).Select
'.ActiveCell.Value = Format(oBOMPeso, "###.###")
Next ii
End With
Else
Exit Sub
End If
'Ordina le righe per ordine alfabetico secondo il codice
Sheets("Foglio1").Select
ActiveSheet.Select
Columns("A:R").Select
Range("A21").Activate
ActiveWorkbook.Worksheets("Foglio1").Sort.SortFields.Clear
ActiveWorkbook.Worksheets("Foglio1").Sort.SortFields.Add Key:=Range("B2:B200") _
, SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
With ActiveWorkbook.Worksheets("Foglio1").Sort
.SetRange Range("A1:R200")
.Header = xlYes
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
End With
ActiveWorkbook.SaveAs filename:=(PercaorsoNomeEst), FileFormat:=xlCSVWindows, CreateBackup:=False, Local:=True
Application.DisplayAlerts = False
ActiveWorkbook.Close
excel_app.Quit 'Chiude definitivamente l'applicazione excel
MsgBox "La distinta è stata esportata correttamente!"
'End
'OK---End Sub
'---TEST---
'Salva il drawing.
drawDoc.Save
'Close the drawing.
Next
End Sub
If Err Then
fileCount = 0
End If
On Error GoTo 0
End If
filename = Dir
Loop
maxCount = 0
directoryCount = 0
End If
End If
End If
dirName = Dir
Loop
Dim i As Integer
Next
End If
End Function
'Funzione che estrae il percorso completo nel quale si trova il file attualmente in uso
Private Function GetFilePatch(ByVal sFullFileName As String) As String
Dim sFilePatch As String
Dim nPos1 As Integer
Dim nPosf1 As Integer
Dim nPos2 As Integer
sFilePatch = sFullFileName
nPos1 = InStrRev(sFullFileName, "\")
nPos2 = InStrRev(sFullFileName, ".")
If nPos1 > 0 Then
sFilePacth = Mid$(sFullFileName, nPos1 + 1)
End If
nPosf1 = InStr(sFullFileName, ".")
If nPos1 > 0 Then
sFilePatch = Left$(sFilePatch, nPosf1 - (nPos2 - nPos1))
End If
GetFilePatch = sFilePatch
End Function
Debug Error image:
