Run addin automatically once Inventor has fully opened
I'd like to run my addin automatically once Inventor has fully opened, without having to interface with it manually.
Currently it loads on startup, but the only way I can see to get it to actually run is to make it load in to the ribbon and hit the button it places there.
Is this possible?
fixed my problem using some COM, but would be interested if there is still a way of doing this internally within addin script...
AlexFielder
Hi Harry,
It isn't something I have looked at in a while but I used to have an Addin present a userform for population drawing property values once a new drawing file had been created.
IIRC I had to use the "ApplicationEvents.OnOpenDocument" Event paying particular attention to the "EventTimingEnum.kAfter" part.
Looking through the Inventor API Help for either of the above should help you.
Alex.
Thanks Ales, I'll check it out.
Harry Keen
Lead Design Engineer
@harry_keen18
Opendesk
Lime Wharf
25 Vyner Street
London E2 9DJ
0800 0149 951
@open_desk
smilinger
I think you should subscribe to the ApplicaitonEvents.OnReady event, which is fired just after Inventor is fully opened.
