Run a Inventor VBA macro when "Checking In" a assembly, part or drawing in Vault
isocam
isocam
Can anybody help?
Is it possible to run an Autodesk Inventor VBA macro when "Checking In" a assembly, part or drawing using Vault?
Many thanks in advance!
Darren
bradeneuropeArthur
What do you exactly mean?
  1. Before check in?
  2. after check in?
you could use your own written command for it, and run your code first and afterwards the check in command.
 like:
public sub (Custom Check in)
"Your commands here"
Dim CmdMan As ControlDefinition Set CmdMan = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop") 'or useVaultCheckin CmdMan.Execute ' or use CmdMan.Execute2 (True)
end sub
Or take a look at this:
https://forums.autodesk.com/t5/inventor-customization/use-inventor-vault-add-in-through-inventor-api...
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
SPALANIAPPANTN47S
While executing this code, how to select Ok button automatically?
If any ideas, Suggest me !!
Thanks in advance!!
bradeneuropeArthur
You can first disable the dialog on check in via the options in the Vault tab.
or use the "AppContextual_OKCmd "
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
SPALANIAPPANTN47S
Thank u @bradeneuropeArthur . Solved
