Rule to switch between view reps and switch between levels of detail
ASchlaack
ASchlaack
Can I please get a rule to switch between view reps and levels of detail?
Example of how I'll use it:
Select Case Paremeter
   Case = 1
      View Rep = View 1
Next
   Case = 2
      View Rep = View 2
Next
End Select
OR
   Case = 1
      Level of Detail = Level 1
Next
   Case = 2
      Level of Detail = Level 2
Next
End Select
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
MechMachineMan
API Help. RepresentationsManager.
It would be way faster for you if you actually learned how to use the other resources and weren't completely dependant on forums/ just plain old lazy.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
ASchlaack
I use that, I post on here what I can't find out on my own.
Aaron Schlaack
Vladimir.Ananyev
My advice is to test your ideas with representations in the Inventor VBA invironment that is good for the debugging. Then you may quite easily migrate your code to iLogic.
Here is the vba code snippet that prints the list of the available LODs and then activates one of them existing LODs:
Sub ChangeLOD()
    Dim oAsmDoc As Inventor.AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    ' Get assembly component definition
    Dim oAsmDef As Inventor.ComponentDefinition
    Set oAsmDef = oAsmDoc.ComponentDefinition
    Dim oRepMgr As RepresentationsManager
    Set oRepMgr = oAsmDef.RepresentationsManager
    Dim oLODs As LevelOfDetailRepresentations
    Set oLODs = oRepMgr.LevelOfDetailRepresentations
    Dim oLOD As LevelOfDetailRepresentation
    For Each oLOD In oLODs
        Debug.Print oLOD.name
    Next
    Dim name As String
    Dim n As Integer
    n = 2
    Select Case n
        Case 1
            name = "BOTTOM"
        Case 2
            name = "TOP"
        Case Else
            name = "Master"
    End Select
    Set oLOD = oLODs.Item(name)
    oLOD.Activate
    Beep
End Sub
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
