Get iLogic to wait for form completion
SharkDesign
Mentor Mentor
SharkDesign
I have got iLogic displaying a form which asks for a few inputs, but then it races off completing the rest of the ilogic code before the form window has been closed.
Is there a way to get iLogic to wait for the form to be closed before carrying on with the next line of code?
Thank you for any help.
Inventor 2016
  Inventor Certified Professional
LukeDavenport
Hi James, try these options in the form. If you add an 'apply' button the form will wait until you hit apply before it runs changes you've made.
Does that work?
Luke
SharkDesign
Thanks for the reply, I tried what you said but it still carries on without waiting.
It's basically an extrusion that changes length and saves the result as a file.
The form is:
My code is this:
JN = iProperties.Value("Project", "Project")
PN = "P8 40x40-" & L
Nm=iProperties.Value("Summary", "Author")
saveFolder = "C:\Users\User\Desktop\Item\"
Nm=myName
iLogicForm.Show("Item Creation")
ThisDoc.Document.SaveAs(SaveFolder & JN & " " & PN & (".ipt") , True)
MessageBox.Show("Part created", "Item create")
Else
iLogicVb.UpdateWhenDone = True
LukeDavenport
Hi James,
I've just tried it myself - If you have an 'Apply' button on the form, then any parameter changes you type in will not be applied to the model until you hit the apply button.
Do you have an event trigger for the rule you pasted? If so why not simply get rid of that and add the rule itself as a button to the form, so that you enter your info on the form and then hit the button to create the copied file.
Luke
SharkDesign
That's pretty much what I ended up doing.
JeremyVosnacos1076
By setting Modal to True within the rule or
Setting Modal as True when you run it using ilogic
iLogicForm.ShowGlobal("Form 1",1)
