Rule to create Custom iProperty as function
Hi gents,
I would like to have Custom iProperty add by iRule, just like :
iProperties.Value("Custom", "A") = PARAMETER1
would create iProperty A with parameter value as for PARAMETER1 as number;
and,
iProperties.Value("Custom", "B") = "Example Text"
would create iProperty B with example text as text,
Question, how to create Custom iProperty to have text and number in one???
iProperties.Value("Custom", "C") = "Example Text" PARAMETER1 (this one input does not work)
Cheers!
MechMachineMan
iProperties.Value("Custom", "C") = "Example Text" & PARAMETER1
You need to use an ampersand to join strings within programming.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
