Rule ilogic o VBA in Inventor 2015 to subtitute and rename a mass of assembly in
Message 1 of 34
Hi, I have a problem:I have an assembly containing a mass of assembleys.
Often I have to update all those assembley changing the last part of their names, the better thing would be substitute each assembly and rename the new one substituing the last part of name with an other. The important thing is that all the assembleys have the same last part of name and I have to substitute this part with the same text for each assembleys.
Just this, not copy the parts and subassembly contained in those assembly,just riutilize them . This assembleys are normal (not ilogic, no iassembly)
Could you write to me a rule (better would be VBA but ok also ilogic if you are able to do by it) to do this automatically for whole assembleys contained in my assembly? I don't need form or similar, it could be sufficiently to write the text to substitute and the newone at code level
Actually I make it by design assistance but I lose a lot of time each time.
Thank you for you help
Replies (33)
Message 21 of 34
Ah ok, no problem, my drawings and assembly will always have the same names.
E.g.:
Xxxed0.iam
Xxxed0.idw
Wwwed0.iam
Wwwedo.idw
Message 22 of 34
Owner2229
Alright, here below is your updated code. You should test it first.
There might be a problem with the document replacing. This code will replace all referenced documents with the one of the same name, so If you have another (different) document placed in the drawing, than it will be replaced as well. The solution for this would require a little bit more coding, so let me know if it is or isn't a problem.
Basicaly it shouldn't be a problem if you're ussing only one assembly document per drawing.
Sub Test()
    Dim TextToFind As String
    TextToFind = "ed0"
    Dim TextToReplace As String
    TextToReplace = "_logo_ed1"
    Dim NewFolder As String
    ' Leave this string empty to copy to current folder
    NewFolder = "C:\MyFiles\"
Dim UpdateDrawings As Boolean
' "True" to update and move drawings, "False" to just update them
CopyDrawings = True Dim oDoc As Document Set oDoc = ThisApplication.ActiveDocument Dim oOcc As ComponentOccurrence For Each oOcc In oDoc.ComponentDefinition.Occurrences Dim aDoc As Document Set aDoc = oOcc.Definition.Document If aDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Dim oName As String oName = aDoc.FullFileName Dim xDoc As Document Set xDoc = ThisApplication.Documents.Open(oName, False) Dim FNP As Integer FNP = InStrRev(oName, "\", -1) Dim oPath As String If NewFolder = "" Then oPath = Left(oName, FNP) Else oPath = NewFolder End If Dim oNewName As String oNewName = Mid(oName, FNP + 1) Dim FRP As Integer
FRP = oNewName.LastIndexOf(TextToFind) If Not FRP = -1 Then oNewName = oNewName.Remove(FRP, Len(TextToFind)).Insert(FRP, TextToReplace) End If xDoc.SaveAs (oPath & oNewName), False xDoc.Close (True)
ThisApplication.SilentOperation = True
Dim yDoc As Document
Set yDoc = ThisApplication.Documents.Open(Left(oName, Len(oName) - 3) & "idw"), False)
Dim oRefFile As FileDescriptor
For Each oRefFile In yDoc.File.ReferencedFileDescriptors
            oRefFile.ReplaceReference(oPath & oNewName)
         Next
If CopyDrawings Then
yDoc.SaveAs (oPath & Left(oNewName, Len(oNewName) - 3) & "idw"), False
Else
yDoc.Save
yDoc.Close(True)
ThisApplication.SilentOperation = False End If Next End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 23 of 34
after a massive use of this rule (with a lot of satisfaction) I see a problem: this rule doesn't make the same operation of "save and replace" button there is in Inventor ,that is replace all the iam files at first level in an assembly  with others with new name and also its part number in iproprietis with the same name of the file name, but new file have the old part numbers!
Is there a method to make the same operation that makes the button "save and replace" ?
And for all the files I have already generated with the rule (hundreds)  is there a method or a new rule to update the old part number with the same name of the file name?
Thank you for your time, I hope you could help me.
I semplified a little your rule , it is sufficiently it salve and rename in the same folder, I attach it below,i use it as a external rule in ilogic:
Dim
TextToFind As String = "CFB" Dim TextToReplace As String = "AAACFB" Dim oDoc As Document = ThisApplication.ActiveDocument Dim oOcc As ComponentOccurrence For Each oOcc In oDoc.ComponentDefinition.Occurrences Dim aDoc As Document = oOcc.Definition.Document If aDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Dim oName As String = aDoc.FullFileName Dim xDoc As Document = ThisApplication.Documents.Open(oName, True) Dim FNP As Integer = InStrRev(oName, "\", -1) Dim oPath As String = Left(oName, FNP) Dim oNewName As String = Mid(oName, FNP + 1) oNewName = oNewName.Replace(TextToFind, TextToReplace) xDoc.SaveAs(oPath & oNewName, False) xDoc.Close(True) End If Next
Message 24 of 34
has somenone some idea about? Thank you
Message 25 of 34
Owner2229
Hey there, the function of "Save As" is held by the code you have.
The function of "Replace" is held by the code you have removed (blue in my post above).
As for the Part numbers, include this in the for each loop:
Dim FName As String = aDoc.FullFileName
Dim FNP As Integer = InStrRev(FName, "\", -1)
Dim PN As String = Microsoft.VisualBasic.Mid(FName, FNP + 1)
PN = Microsoft.VisualBasic.Left(PN, Microsoft.VisualBasic.Len(PN) - 4)
iProperty(aDoc, "Part Number").Expression = PN
Here is the function called by the code above, add it somewhere below your code:
Public Function iProperty(oDoc As Inventor.Document, oProp As String) As Inventor.Property
	Dim oPropsets As PropertySets = oDoc.PropertySets
	Dim oPropSet As PropertySet = oPropsets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")
	Try
		iProperty = oPropSet.Item(oProp)
	Catch
		oPropSet.Add("", oProp)
	End Try
	oPropsets = Nothing
	oPropSet = Nothing
End Function
Mike
Message 26 of 34
THank you for your time.
But I don't know where i have to add the code you post, Because I have some error when I try to run the new macro.
I've tried you "sub Test" but it returns an error and i post a screenshot about.
Could you help me please?
And also I'm not able to make a function that updates the part numbers with the same name of the file name of the files in a assembly,some errors also there
Message 27 of 34
Owner2229
Here below is the updated version of the code. It sould now also work for multi level assemblies (you can disable it by commenting out the blue lines).
It no longer goes throught every occurrence, so it sould be a bit fater.
Here's the whole functionality of the code:
1) Set's focus on currently open (active) document
2) Goes throught every refferenced document...
    - If the document is an assembly, it goes throught every of it's refferenced documents
    - Renames it and saves under new name
    - Writes in the new PartNumber
    - Replaces the refference in the assembly
3) Renames, updates PartNumber and saves under new name the top assembly (can be disabled by commenting out the green text)
Let me know if this is what you wanted the code to do and/or if there're any mistakes or errors.
Also this is the VBA version of the code (it took some time to translate), so let me know if you want the VB.Net version instead.
Sub Test()
    TextToFind = "CFB"
    TextToReplace = "AAACFB"
    Call ReplaceSubs(oDoc, TextToFind, TextToReplace)
oNewName = oDoc.FullFileName
oNewName = GetNewName(oNewName, TextToFind, TextToReplace)
oDoc.SaveAs oNewName, False
UpdatePartNumber(oDoc)
oDoc.Save ThisApplication.SilentOperation = False End Sub Public Sub ReplaceSubs(oDoc As Inventor.Document, TextToFind As String, TextToReplace As String) Dim oRefFile As FileDescriptor For Each oRefFile In oDoc.File.ReferencedFileDescriptors Dim oName As String oName = oRefFile.FullFileName Dim aDoc As Inventor.Document Set aDoc = ThisApplication.Documents.Open(oName, False) If aDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Call ReplaceSubs(aDoc, TextToFind, TextToReplace) End If Dim oNewName As String oNewName = GetNewName(oName, TextToFind, TextToReplace) aDoc.SaveAs oNewName, False
UpdatePartNumber(aDoc)
aDoc.Save aDoc.Close (True) oRefFile.ReplaceReference (oNewName) Next End Sub
Public Function GetNewName(oName As String, TextToFind As String, TextToReplace As String) As String
Dim FNP As Integer
Dim oPath As String
GetNewName = Replace(oNewName, TextToFind, TextToReplace)
End Function
Public Sub UpdatePartNumber(oDoc As Inventor.Document) Dim PN As String PN = oDoc.FullFileName Dim FNP As Integer FNP = InStrRev(PN, "\", -1) PN = Mid(PN, FNP + 1) PN = Left(PN, Len(PN) - 4) iProperty(oDoc, "Part Number").Expression = PN End Sub Public Function iProperty(oDoc As Inventor.Document, oProp As String) As Inventor.Property Dim iPro As Inventor.Property On Error GoTo IPCatch Dim oPropsets As PropertySets Set oPropsets = oDoc.PropertySets Dim oPropSet As PropertySet Set oPropSet = oPropsets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}") iProperty = oPropSet.Item(oProp) IPCatch: Call oPropSet.Add("", oProp) iProperty = oPropSet.Item(oProp) End Function
Mike
Message 28 of 34
Hi, thank oyu for your solution, but there is some issues.... I add some missing "call" and when I try to execute this macro It return an error: i attach a screenshot. Could you make something about please? If you are more sure writing a rule instead a macro for me no problem. Thank you in advance for your help
Message 29 of 34
here is the screenshot
Message 30 of 34
Owner2229
Hmm, it looks like it want's the parameters enclosed in brackets (it throwed an error when I tried it on my PC).
Let's try it like this (orange is what I changed).
If it won't work, try to comment out the SilentOperation sets.
Sub Test()
    TextToFind = "CFB"
Call oDoc.SaveAs(oNewName, False)
Call UpdatePartNumber(oDoc)
Call oDoc.Save() ThisApplication.SilentOperation = False End Sub Public Sub ReplaceSubs(oDoc As Inventor.Document, TextToFind As String, TextToReplace As String) Dim oRefFile As FileDescriptor For Each oRefFile In oDoc.File.ReferencedFileDescriptors Dim oName As String oName = oRefFile.FullFileName Dim aDoc As Inventor.Document Set aDoc = ThisApplication.Documents.Open(oName, False) If aDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Call ReplaceSubs(aDoc, TextToFind, TextToReplace) End If Dim oNewName As String oNewName = GetNewName(oName, TextToFind, TextToReplace) Call aDoc.SaveAs(oNewName, False)
Call UpdatePartNumber(aDoc)
Call aDoc.Save() Call aDoc.Close (True) Call oRefFile.ReplaceReference (oNewName) Next End Sub
Dim FNP As Integer
Dim oPath As String
End Function
Mike
Message 31 of 34
Thank you for your time, but neither this time it goes fine.
There is something wrong about the function "saveas", I attach the screenshot below, when I run the sub it crash there,where  i mark in blue in the screenshot...
Message 32 of 34
Owner2229
I've found the issue. I forgot to add the path back to the filename after the replacement.
I'm also not sure (as I didn't work with VBA for some time) if this statement should have brackets or not, so test it out:
Sub Test()
    TextToFind = "CFB"
Dim FNP As Integer
Dim oPath As String
oNewName = Replace(oNewName, TextToFind, TextToReplace)
GetNewName = oPath & oNewName
End Function
Mike
Message 33 of 34
MechMachineMan
Quick question Mike:
Won't this current set-up ruin the references in all of the current assembly docs that aren't getting renamed?
As I understand, it will open up an assembly, go through, save new versions of the referenced files, and replace the references, but doesn't actually change the assembly document first?
So shouldn't this actually look more like this to actually replace the assembly file first?
Sub Test()
    TextToFind = "CFB"
    oNewName = GetNewName(oDoc.FullFileName, TextToFind, TextToReplace)
    Dim oNewDoc As Document
    Set oNewDoc = ThisApplication.Documents.Open(oNewName, True)
    Call ReplaceSubs(oNewDoc, TextToFind, TextToReplace)
    Call UpdatePartNumber(oNewDoc)
    Call oNewDoc.Save()
    Call oDoc.Close() 'This might cause a "Pure Vital Function call error/Catastrophic failure error" if so, remove it
End Sub
        Dim oName As String
        Dim oNewDoc As Inventor.Document
        Set oNewDoc = ThisApplication.Documents.Open(oNewName, False)
        Call aDoc.Close()
        If oNewDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
        Call oNewDoc.Save()
        Call oNewDoc.Close (True)
    Next
End Sub
    Dim FNP As Integer
    Dim oPath As String
End Function
    Dim PN As String
    Dim FNP As Integer
End Sub
IPCatch:
End Function
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 34 of 34
Owner2229
Hey, you're kinda right, it will "mess up" the references (kind of), but that's the intention, because when you change a document you're changing a temp copy of the original document, so when you do a "Save As", you're actualy saving the temp document. Basicaly, all the original data are safe as long as you don't mistakenly run "Save" function instead of "Save As".
As you can see in the rule, I'm first calling "Save As", then I'm updating the PartNumber, as it is derived from the new filename and finnaly "Save" to save the part number in the file.
Hmm, you just gave me an idea... As I already know the new name, I don't realy need the second "Save", as I can write in the new PartNumber before the "Save As".
So, here's the little change. It sould run slightly faster this way.
Sub Test()
    TextToFind = "CFB"
Call UpdatePartNumber(oDoc, oNewName)
Call UpdatePartNumber(aDoc, oNewName)
Call aDoc.SaveAs(oNewName, False) Call aDoc.Close (True) Call oRefFile.ReplaceReference (oNewName) Next End Sub
Dim FNP As Integer
Dim oPath As String
End Function
Public Sub UpdatePartNumber(oDoc As Inventor.Document, PN As String) Dim FNP As Integer FNP = InStrRev(PN, "\", -1) PN = Mid(PN, FNP + 1) PN = Left(PN, Len(PN) - 4) iProperty(oDoc, "Part Number").Expression = PN End Sub Public Function iProperty(oDoc As Inventor.Document, oProp As String) As Inventor.Property Dim iPro As Inventor.Property On Error GoTo IPCatch Dim oPropsets As PropertySets Set oPropsets = oDoc.PropertySets Dim oPropSet As PropertySet Set oPropSet = oPropsets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}") iProperty = oPropSet.Item(oProp) IPCatch: Call oPropSet.Add("", oProp) iProperty = oPropSet.Item(oProp) End Function
Mike
