Rule ilogic o VBA in Inventor 2015 to subtitute and rename a mass of assembly in
Message 1 of 34
Hi, I have a problem:I have an assembly containing a mass of assembleys.
Often I have to update all those assembley changing the last part of their names, the better thing would be substitute each assembly and rename the new one substituing the last part of name with an other. The important thing is that all the assembleys have the same last part of name and I have to substitute this part with the same text for each assembleys.
Just this, not copy the parts and subassembly contained in those assembly,just riutilize them . This assembleys are normal (not ilogic, no iassembly)
Could you write to me a rule (better would be VBA but ok also ilogic if you are able to do by it) to do this automatically for whole assembleys contained in my assembly? I don't need form or similar, it could be sufficiently to write the text to substitute and the newone at code level
Actually I make it by design assistance but I lose a lot of time each time.
Thank you for you help
Replies (33)
Message 2 of 34
Owner2229
1) so you want the rule to "update" the file names of the current files. Not copy them, just rename the existing parts and update the refferences in assys.
Right?
2) Should the file names update for both parts and assys or just for parts?
3) Now to the file name. How does the "last part of it" (LP) look like? Something like this?
C:\SomePath\MyAwesomePart Nr.105 MySupperLastPartOfName.ipt
4) Can the same text as in "LP" be in somewhere else in the rest of the file name, or is it unique?
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 34
Hi and thank you for your time.
1- well,maybe it would be better to have a copy of the assembleys ,but no their components under ,if possible,if just rename no problem,I could male a copy of all before to another path so I could have the old revisione.
2-The assembly that contain the assembleys is just to keep all there,but I don't need to rename it. The assembleys contained in it has to be "saved as " ,to undestand you, just those assembleys, not their sub parts/assembleys. I hope to explain right
3- the lenght of whole assembleys is the same, the path is the same ,and the last part is always "ed0", and I have to substitute it with "_logo_ed1" this time,but in future this text can be differenti,but no problem,I will change the source code eventually
4-I think that text doesn't be in the rest of filename. I think you ask me this because you think to male a search ? Please to considerazione also to take a function like "right()" or similar if there is
Thank you again a lot
Message 4 of 34
Owner2229
Hi, so is this schema accurate?
MainAssy            - do nothing
    SubAssy1        - copy and rename
        Part1          - rename
        Part2          - rename
        SubAssy2    - do nothing
            Part3      - rename
            Part4      - rename
    SubAssy3        - copy and rename
        Part5          - rename
    Part6              - rename
Mike
Message 5 of 34
No, I'm sorry,maybe I explained not so much good.
The right schema is this below:
        Part1          - do nothing
        Part2          - do nothing
            Part3      - do nothing
            Part4      - do nothing
        Part5          - do nothing
    Part6              - copy and rename
    SubAssy4       -copy and rename
To explain just the first level below the mainAssy!
Message 6 of 34
Owner2229
Alright then, here is your code:
Dim TextToFind As String = "ed0"
Dim TextToReplace As String = "_logo_ed1"
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oOcc As ComponentOccurrence
For Each oOcc In oDoc.ComponentDefinition.Occurrences
    Dim aDoc As Document = oOcc.Definition.Document
    If aDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
        Dim oName As String = aDoc.FullFileName
        Dim xDoc As Document = ThisApplication.Documents.Open(oName, True)
        Dim FNP As Integer = InStrRev(oName, "\", -1)
        Dim oPath As String = Left(oName, FNP)
        Dim oNewName As String = Mid(oName, FNP + 1)
        oNewName = oNewName.Replace(TextToFind, TextToReplace)
        xDoc.SaveAs(oPath & oNewName, False)
        xDoc.Close(True)
Next
Mike
Message 7 of 34
Thank you for your time!
But if I try to paste this code in Inventor VBA module it give's many errors... I don't know why.
Could you help me?
Message 8 of 34
Owner2229
Can you provide both error screens please?
Mike
Message 9 of 34
Message 10 of 34
Owner2229
Hi, the code I send you was iLogic, not VBA. And you have placed the code outside of Sub-Routine.
Sub Test()
' ... Code goes here
End Sub
Here's the VBA version of the code as whole Sub-Routine:
Sub Test()
TextToFind = "ed0" Dim TextToReplace As String
TextToReplace = "_logo_ed1" Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument Dim oOcc As ComponentOccurrence For Each oOcc In oDoc.ComponentDefinition.Occurrences Dim aDoc As Document
Set aDoc = oOcc.Definition.Document If aDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Dim oName As String
oName = aDoc.FullFileName Dim xDoc As Document
Set xDoc = ThisApplication.Documents.Open(oName, True) Dim FNP As Integer
FNP = InStrRev(oName, "\", -1) Dim oPath As String
oPath = Left(oName, FNP) Dim oNewName As String
oNewName = Mid(oName, FNP + 1) oNewName = Replace(oNewName, TextToFind, TextToReplace) xDoc.SaveAs (oPath & oNewName), False xDoc.Close (True) End If Next End Sub
Mike
Message 11 of 34
Fantastic!!!! A last thing: if I would chose a new path to save the new files? It is sufficiently to do it at code level,not with a form.
Message 12 of 34
Owner2229
Here you go:
Sub Test()
    TextToFind = "ed0"
Dim NewFolder As String
' Leave this string empty to copy to current folder
NewFolder = "C:\MyFiles\"
Dim oDoc As Document Set oDoc = ThisApplication.ActiveDocument Dim oOcc As ComponentOccurrence For Each oOcc In oDoc.ComponentDefinition.Occurrences Dim aDoc As Document Set aDoc = oOcc.Definition.Document If aDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Dim oName As String oName = aDoc.FullFileName Dim xDoc As Document Set xDoc = ThisApplication.Documents.Open(oName, True) Dim FNP As Integer FNP = InStrRev(oName, "\", -1) Dim oPath As String If NewFolder = "" Then
Else
oPath = NewFolder
End If Dim oNewName As String oNewName = Mid(oName, FNP + 1) oNewName = Replace(oNewName, TextToFind, TextToReplace) xDoc.SaveAs (oPath & oNewName), False xDoc.Close (True) End If Next End Sub
Mike
Message 13 of 34
You rule!!!! Thank you!!!
Message 14 of 34
Owner2229
You're welcomed 😉
Mike
Message 15 of 34
This problem is a lot more complex than the simple answer implys.
1)  The op specifies parts to be copied and renamed under the master assembly.
2)  Nothing is said of drawing files.  Do they need to be processed as well?
3)  The replace function can get you into trouble if it is not 100% specific.  if "ed0" exists anywhere in the full path filename unwanted renaming could happen.
A better solution for #3 is to include the file extention witht he replace() funciton.
newFilename = replace(oldfilename,"ed0.ipt","_logo_ed1.ipt")
newFilename = replace(oldfilename,"ed0.iam","_logo_ed1.iam")
newFilename = replace(oldfilename,"ed0.idw","_logo_ed1.idw")
Message 16 of 34
Owner2229
Hi, these are actualy valid concerns. Roberto, do you need your drawings' files to be renamed / moved as well and updated to reference to the new assembly names?
Here is the code updated, with 3) fixed.
Sub Test()
    TextToFind = "ed0"
            Dim oName As String
            Dim FNP As Integer
            Dim oPath As String
            Else
                oPath = NewFolder
Dim FRP As Integer = oNewName.LastIndexOf(TextToFind)
If Not FRP = -1 Then
oNewName = oNewName.Remove(FRP, Len(TextToFind)).Insert(FRP, TextToReplace)
End If xDoc.SaveAs (oPath & oNewName), False xDoc.Close (True) End If Next End Sub
Mike
Message 17 of 34
This time i don't need my drawings' files to be renamed / moved as well and updated to reference to the new assembly names. But it could be very useful to have also this option!
Are you so kindly to include a check with this?
Thank you a lot
Message 18 of 34
Owner2229
Are the Drawings' filenames the same as the Assemblies' ?
E.g.:
MyAssyOne.iam
MyAssyOne.idw
Or do they differ somehow?
Mike
Message 19 of 34
Yes, we consider to have same filename to not complicate toomuch the things. But would you able to make it also with differenti names?! Wow
Message 20 of 34
Owner2229
It wouldn't be a problem if the different names are made with an rule in theyr naming. I believe you know what I'm pointing at.
E.g.
MyAssyOne.iam
MyAssyOneX1A.idw
MyAssyTwo.iam
MyAssyTwoX1A.idw
The problem might come with completely different names. It would have to be handled by exceptions, so each drawing will be one line of code (imagine it for hundreds of drawing).
E.g.
MyAssyOne.iam
MyDrawingXZA.idw
MyAssyTwo.iam
MyXFADrawing.idw
Mike
